Maybe it is leaking from the water valve that is just ouside of your dishwasher, There is a flexible line attached to the water valve that goes into the dishwasher where it is also attached. Get a flashlight and look around, if you see the valve see if the connection is leaking. If it is, see if you can tighten it. You can also shut the water to the dishwasher off here. Don't forget to turn it back on after repairs.
I see the water leaking out the bottom plastic cover through the two little holes. I do not see water leaking around the top seal. I assume it is coming from a seal on the bottom. Is there a manual that shows how to take the dishwasher apart to get to the seals? I have the parts sheet which shows the exploded views where the parts are shown. Much appreciated!
Water is being forced out under the bottom door seal. Is the lower spray arm melted on the bottom? Or is there something directing the water flow toward the bottom of the tub instead of up toward the dishes?
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
