Question about Canon MV700i Mini DV Digital Camcorder
Vertical lines I have borrowed a camera.  When I switch my camera on, there is no picture, only vertical lines.  Is it on some sort of setting or is the camera damaged.  I hope you can help. Thanks Scott
  • 1 more comment
  • scottybones Aug 13, 2008
    Thankyou for your response Bubbabear64.
    The vertical lines remain when you move the screen around.  The lines get wider apart if you zoom out.  Brighter objects appear brighter on screen but you cannot make out the picture because of the vertical lines.
    Thanks Scott
    Yep the lines appear on the tape after recording.  Audio is OK.
    I will take it to the shop
    Thanks again
    Scott
  • Tim Babcock
    Tim Babcock May 11, 2010
    If you move the screen around, does the lines go away?
  • Canon Master
  • 2,794 Answers
If the lines appear on the tape this way when it is recorded, then the CCD unit is going out on the camcorder. If it isn't recording the lines then the viewfinder wiring or screen is damaged.
You should problably take it into a camera shop to see if its worth fixing.
Posted on Aug 13, 2008
Anything to do for vertical lines on screen?
most likely a damaged sensor. How about the pictures? Do they show these lines on them too?
Oct 23, 2015 | Canon PowerShot ELPH 340 HS Digital Camera...
Vertical lines on video
best bet to get that video on pc 1st ok then convert it to dvd format 720x480 29.97 fps mpeg 2 use allok software online to convert then burn to dvd play perfect use nero 7 to make dvds proably is flat screen your resoution proably dont match up or the verticaly sync in hertz is higher cuses the vertical lines so do that way to make pro videos
Jan 27, 2008 | Video Cameras
Black screen when shooting vertically
I think there is some setting problem you must see the camera settings and check the vertical area. I think vertical settings are disturbed and you need to reset vertical settings.
Jul 14, 2013 | Nikon COOLPIX L810
Tv goes to straight line in center of picture then
It happens when Vertical deflection stops as Vertical Out IC becomes hot or does not get vertical signal.
Please check electrolytic capacitors and dry solder joints in vertical out section in TV.
Aug 12, 2009 | Sanyo Televison & Video
Tosh widescreen ghosting vertical lines
there is no convergence adjust in a 32" tv. Convergence is done when there is more than 1 picture tube, ie; 50" projection sets have 3 tubes so convergence can go out. post the model number of your set and we can help more, BMW Rider
Dec 14, 2007 | Televison & Video
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Sony CRT Tv (KV-T29SZ8)
When you see white lines at the top of the screen, it means that the pump-up capacitor next to the vertical output IC is bad and the IC is about to quit. When the output finally quits, you get a black screen with possible dim spots. The vertical output IC and its pump-up cap will have to be replaced, and the little fuse resistors next to the flyback in the + and - supplies to the vertical output IC must be checked too. If you have experience working on TV's then you can do it yourself, but if not then have the set serviced by a tech experienced in Sony sets.
Aug 09, 2007 | Sony KV-35S42 35" TV
A horizontal or vertical red line appears on picture.
Red lines are caused by glare. Avoid photographing shiny surfaces that reflect excessive amounts of light into your lens.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Canon MV700i Mini DV Digital Camcorder Logo
221 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
