Question about HP DeskJet 3745 Printer
My printer is stop printing
Printers all caudge is set allready.but printer cant printing any paper
  • Anonymous Aug 18, 2008
    printer stops printing all of asudden
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Are these still current issues?
Posted on Aug 20, 2008
Hp laserjet 5200
firstly check whether the problem is internal or external-
Have the printer print out the config page- if you can see the image then the issue is external to the printer- check your PC settings
If you cant see an image-
You say you have allready changed the toner unit, was this before the fault or after?
under where the drum/toner cartridge sits there should be a Black 'transfer' roller that will line up with the drum surface when inserted- if this is missing or failed then the image cannot be ' transferred' from the drum to the paper. this is just one possibility, if your not sure wheher the transfer roller is working - stop a print half way through- remove the paper and toner unit - slide the drum surface protector to the side and look at the drum surface for a latent reversed image in toner on the surface of the drum, if you can see an image the problem lies with the transfer element, if you cant see an image then it could possibly be the charge chorona/ HVT PWB / Laser unit, main Pca, power supply hope this helps
Mar 11, 2014 | HP Hewlett Packard LaserJet 5200 Printer
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
I cant get my printer HP2055 dn to print letter paper..it just goes to the legal tray (3). I also can't figure out how to get to the menu on the printer to see if the trays are set correctly.
Go to your menu and select paper handling. From there you can reset the paper settings. If paper will not pull from tray 2 you probably have worn out feed rollers.
Feb 12, 2013 | HP LaserJet P3005n Printer
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
The printer won't stop printing, nor will it print the item I selected to print; it just  keeps spooling and spitting out paper.  HELP!!
hi this sounds like you are using the wrong driver for the printer, does it just spit out gobbeldy gook on the paper? if so this is the reason, un-install the printer driver you have currently for this printer and go to
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=uk&dlc=en&sw_lang=&product=3418705#N644
here you will find the correct driver for your printer i have chose the page allready, i dont know what OS you are using, but i chose the xp drivers, if incorrect, just click home page for hp and do it again till you get your OS drivers...hope this helps
May 29, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP4L Printer-While printing,paper cycles1/2the way, printer stops
Check the paper size setting in the software and print driver. Sounds like a non-standard paper size setting.
Feb 15, 2009 | HP LaserJet 4L Printer
I cant print
i need software for my hp deskjet 3745 printer
Oct 21, 2008 | HP DeskJet 3745 Printer
Printing
I have found that the printer will automatically feed out the back if you have the "paper catcher" pulled "OUT". Try pushing the back "paper catcher" "IN".
Apr 14, 2008 | OKI B4350 Laser Printer
Epson C120/ Stops at Perforated line
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Bright White Paper
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Paper Glossy
Epson Photo Quality Self-adhesive Sheets
Epson Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-sided
Epson Presentation Paper Matte
Epson Ultra Premium Photo Paper Glossy
Jan 23, 2008 | Epson Stylus C60 InkJet Printer
HP DeskJet 3745 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
