Servis M6712w washing machine. Suddenly decided to stop working, fuse OK but no lights on display. Power to machine OK, Visually checked all parts and board but nothing obvious blown and no loose connections. Anyone with any advice!!
SOURCE:
gittos73
  • 244 Answers
SOURCE: No power to washing machine but fuse is ok...
could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
Posted on Aug 22, 2007
SOURCE: Stopped Dead
these machines only have 2 problems
dive coupling no wash or spin
or lid switch machine totallaly dead normally caueded by droping heavily & breaking the housing of the lid switch
Posted on Oct 30, 2008
barkencoa
  • 3463 Answers
SOURCE: No power running to SERVIS washing machine
Try disconnecting the heater element first and see what happens if still same unplug motor and try again, it is a process of elimination.
Plz rate solution.
Thanks.
Posted on Dec 14, 2008
  • 135 Answers
SOURCE: no power
This is a lack of neutral feed to the door switch. The feed comes from the circuit board which is where the fault lies. However if fitting a new board i would advise replacing door switch as it was probably the initial cause.
Hope this helps & thanks for using Fixya.
Posted on Dec 16, 2008
venexcsd
  • 1185 Answers
SOURCE: Hotpoint , no power, full of water
Turn off the water supply to the machine
Take the drain hose off the back of the machine and drop it into a bucket , you will need to do this several times.(Take off any clips that stop it from being laid flat on the floor)
Once all of the water is out of the machine try powering it up again, if it lights up do a spin to get the clothes dry , leaving the outlet hose in the bucket.
If that works then once the machine is dry try turning on the water supply with the machine turned off , if water runs into the machine then you have a faulty fill valve.
If that is ok then check the pressure switch and Air Bell which sits on the back of the main drum you could have a soap ball in the Air Bell which will false out the machine and cause overfilling
If there is no power check the mains supply to the wall outlet then the plug top wiring and any fuse fitted inside the plug top
After that it is down to a man with a test meter
Posted on Jul 17, 2009
Washing machine just stopped working.
Hi,it could be the programe board,or could just be the starter switch,just food for thought all the best hope you sort it.
Nov 26, 2015 | Washing Machines
AEG L11842VIT
the controller needs checking out
Dec 23, 2013 | Dryers
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
Servis 7kg 1500 AA - bush's and motor, ok and
relay is stacked so you start the machine off position power on the wash butten you will check this method
Sep 13, 2011 | Washing Machines
Washing machine stopped working,no power,no display checked fuse,fuse ok.hotpoint wt761
Check the power outlet, the plug and the cable or with the appropriate tester see if you have mains power where the power cable connects to the machine wiring.
Jan 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
LED display is blank. No lights on display panel. There is power present at rear terminals. Machine stopped part way through wash cycle. Any thoughts? Thank You.
Possible that there is line break to the panel board.So firsst you must check this out before we can go further.
If no power check the wire for break.
If power is coming in to the board , check fuse, if fuse blows it ispower issue,failure in the power circuit.
If power is Ok , then the processor controller is defective.
Might have to replace the board then.check cost and proceed.
Hope this helps Good day
Aug 18, 2010 | Washing Machines
Aquarius 1200 WM64 - machine does not start
If you already replaced the fuse, next part to inspect is the control board behind the timer.
If that is ok, check the wiring harness, the socket and the power cord.
Feb 03, 2009 | Hotpoint WMA40 Front Load Washer
New washing machine servis M6725,dispenser drawer will not open.only got it yesterday
i have just used my servis washing machine 1300 aa and just went to put a new load in and there is no power to the machine at all i have checked the fuse and the plug wiring what else can i dp please advise???????
Jul 29, 2008 | Washing Machines
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
