When i want to reply to a text message is only gives me the option to reply using multimedia message. how do i reply to text message with a text message?
I simplified the "getting rid of predictive text" instructions for people with the cheap STRAIGHT TALK LG phones! a)Push the message button directly above the SEND button. b)You\'re at the message screen to type in. c)click on "options," lower left of your message screen. d)click "text entry mode." e)then choose "abc," click on "set" which appears on that screen. You\'re done. You can now dang well type what you want. That\'s how people in the "factory default setting" department get their jollies!
Changing your text message settings Your KC550 message settings are predefined so that you can send messages immediately. If you would like to change the settings, you can do this using the Settings options. Press Menu, select Messaging, then choose Settings and Text message. You can make changes to: Message types - Convert your text into Voice, Fax, Paging, X.400, Email or ERMES. Validity period - Choose how long your message is stored at the message centre. Delivery report - Choose to receive confi rmation that your message was delivered. Reply charging - Choose to be billed for your message recipient’s reply. Message centre number - Enter the details for your message centre. Character encoding - Choose how your characters are encoded. This impacts the size of your message and therefore data charges. Send long text as - Choose whether to send your message as SMS or MMS when you enter a text longer than 2 pages in the message field. Bearer setting - Choose whether to send your messages via GSM or GPRS. Changing your multimedia message settings Your KC550 message settings are predefi ned so that you can send messages immediately. If you would like to change the settings, you can do so using the Settings options. Press Menu, select Messaging, then choose Settings and Multimedia message. You can make changes to: Slide duration - Choose how long your slides appear on screen. Priority - Choose the priority level of your multimedia message. Validity period - Choose how long your message is stored at the message centre. Delivery report - Choose to allow and/or request a delivery report.
then click save. This will allow the t-zone to work on your browser. Next, to set up your MMS settings, do the following: Menu->Messaging->Message Settings->Multimedia Message->Message Center->Options->New
then save it, and activate that profile. If all goes well, those should be the correct setting for tmobile tzone and mms on an unlocked AT&T CU720 Shine as of October 18, 2008
This may be the problem...
Go to messages,
press menu ( - )
go to message setup,
then MMS message setup,
then go on composing MMS,
change the reply type to short reply
when you go "new message" in the messages menu it should give you an option of text message as well as multimedia message and other things. If the problem is when replying to messages it should automatically send in text format and if it doesn't then it should once you have sent some "text" messages from the "new message" option. Hope this helps :-)
I have the same problem, cannot get sms to be the default
