Question about Tomtom GO 720 GPS Receiver
Tomtom go720 can't connect to austrailia map screen says problem with map you cannot use this map on this device: Austrailia tried to press continue but nothing changes. thanks
  • i0dont0know Feb 13, 2009
    same problem as other person but with the xl.. think its a corrupt map initially purchased via ebay
  • 25 Answers
Most of ebay purchases are sold with maps from other devices and then played with alittle to get them running on your device, so when you update, say bye bye to your map, do not update if you buy from ebay, unless you buy the real map then your fine
Posted on Feb 16, 2009
I have forgot my password on tomtom go720 how do
OK remove the Battery from inside, and look for a little "Hole" and push a ... say, a straightened Paper Clip and press it, hold for a second or so, & reassemble. You should be all good.
Feb 12, 2010 | Tomtom GO 720 GPS Receiver
Screen reads"no maps found"
I found this article online, and it may work for you:
"Ok this has worked on at least four tomtom one’s
And one xl’s that i have tried,
First of all connect your tomtom to your computer.
making sure your online,Go to log on.
if you’ve not created an account create one now.
If you’ve had to create an account restart tomtom home.
You should have the tomtom home screen in front of you,
Now even if tomtom home is showing you logged in, ignore
this click your email adderss in the top right hand side of the screen
and log in again and click continue.
Then click Device/disconnect device.
Now your tomtom will update itself and your maps will be restored"
Jan 11, 2008 | Tomtom One Europe v2 GPS Receiver
My computer wont detect my tom tom go
go to tomtom's website and manually download their software. Save it to your HD and run it.
The program should automaticly load the correct drivers and will prompt you when to connect the GPS.
TAKE NOTE of how long you are allowed to get free map updates and make sure you do update the maps before that time expires.
also with my GO720 I skipped an update so instead of the update costing $49 they now want double that because my maps are 2 revisions old.
Dec 27, 2009 | Tomtom GO 720 GPS Receiver
No maps
You probably have a directory on your Storage Card called \Storage Card\My Documents\Map_Name
copy the Map_Name folder to the root of your Storage Card
so you have \Storage Card\Map_Name
restart TomTom and it should pick up the map back. if this didnt work then probably the card directory where the map is stored may corrupt or unreadable try reinstalling the map
at least this has worked in many tomtom one’s
please let me Know if this has worked for you.hope this helps pls apprecite by rating as fixyaa thanks and Godbless
Nov 23, 2008 | Tomtom GO 300 GPS Receiver
There are no speaking directions on my TomTom GO720 e.g. for 'turn left' or 'take the next exit' or 'continue for 3 miles'. It only beeps for speed cameras etc. We have ticked all the boxes on the sound...
Hi there
As the TomTom is making beeping sounds, its a good indication that its not a hardware fault, it sounds to me its a software issue.
What you could do is try to reinstall the voices on your device. To do this, follow these steps:-
I presume you have TomTom Home installed already, if not you can download it from
http://www.tomtom.com/home
STEP 1 Make a Backup
  • Connect your TomTom to the computer and switch it on
  • Open TomTom Home
  • Click on 'backup and restore' and make a backup if you haven't done so already
Once the backup has been made, please do the following:-
STEP 2 Remove the existing voice files
  • Open My Computer, you will see the TomTom as two removable drives, one will be the internal memory and one will be for the SD card slot on the device.
  • Click into the Internal memory drive, you should see a whole load of files and folders.
  • You should see a folder called LoquendoTTS or Loquendo, click into this folder and delete the contents (all the files and folders inside the loquendo folder)
  • Go back to the root directory of the TomTom and delete the folder 'Voices'
STEP 3 Download and Reinstall the voices via TomTom Home
  • Go back to TomTom Home
  • Click on Add Maps, traffic and Voices
  • Select Voices. Loacate the voice of Jane and Tim and add them to your device
  • Go back to the main menu of TomTom Home, click on Add Maps, traffic and Voices -> Computer Voices and install the voice of Kate or Simon (UK English computer voices)
  • Close TomTom Home and also Close it from the system tray. (in the bottom right hand corner of your screen down by the computer clock, you should see a red icon for TomTom Home, Right click on it and choose 'exit')
STEP 4 Install the Clear Flash Tool from TomTom
  • Once Home has closed completely, please download and install the clear flash tool from:- http://www.tomtom.com/updates/clear_flash/clear_flash.exe (Home must be completely closed, otherwise it may not install correctly)
  • Accept the license agreement and keep pressing the Next arrow until the clear flash tool has installed.
  • Your device will start flashing to say there is some activity on your device
  • When your device has finished flashing on the screen (might take a minute), use the 'safely remove hardware' feature of your PC to disconnect the TomTom
  • Switch the TomTom off then take it out of the dock.
STEP 5 Test the voices
  • Switch the TomTom back on, but not connected to the dock
  • Let it load up to the main navigation screen
  • Tap onto the menu and tap onto 'Change Preferences -> Voice Preferences'.
  • Select a non-computer voice i.e. Jane or Tim and press test. You should now hear the voice instruction
  • Try selecting the voice of Kate or Simon i.e. the computer voices, and press test, you should now hear the computer voice.
This should get the voices working again, if not it might be worth giving TomTom Support a call and they can talk you through it.
Hope this works for you
regards
The Warlock
Sep 17, 2008 | GPS
Tom tom go 720 product code
The Go720 do not use a product code, if the map are version 7xx
If the map you are trying to install is version 6xx, then you need to activate.
For references and How Ho, visit:
http://www.tomtom.com/support/index.php?Language=4&query=productcode&FID=2150
Apr 14, 2008 | Tomtom GO 700 GPS Receiver
Downloading Free Maps for TomTom GO 720
I want dowloading free maps for tom tom go 720
Apr 02, 2008 | Tomtom GO 720 GPS Receiver
Tomtom GO 720 GPS Receiver Logo
88 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
