Hygena diplomat apm 8512 washing M/C. the "dispenser drawer" has 3 compartments. compartment 3 (fabric conditioner) when I fill with conditioner the level does not go down when the washing m/c goes thro' its cycle.IE its not using any conditioner. I've cleaned the tray out so no blockages there,what can you suggest as the answer to the problem? Also where can I get a manual for this appliance from? regards Mr M Cartwright
SOURCE: Fabric softener compartment problem.
Squeee, It's been more than a year since you posted this so I guess you must know the answer. It sounds like a Visit from an engineer(?) I've got exactly the same problem with a Servis Easilogic 1500 and would appreciate knowing what you had to do to resolve the issue.
Posted on Jul 05, 2007
  • 4 Answers
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
SOURCE: Conditioner is not used in the wash cycle
I had the same problem with my Bosch Classixx 1200 Express.
It was fixed today & I now know what to do in the future if it happens. The water gets into the soap/ conditioner dispenser drawer via 2 pipes. One points to the main detergent compartment and the other to the pre-wash and conditioner compartments. The pipes become clogged with a type of mould. This meant that in my machine the water was bypassing the conditioner. I had already removed the drawer and cleaned it up and cleaned the jets above with an old tootbrush but it hadn't solved the problem. The repair guy used a cable tie (one of those that is quite firm & will lock) and pushed it up inside the bigger jets. This loosened the black gunge. Then ran water thru from start of the basic cycles and all is now OK
Posted on Jan 18, 2008
woodchuck789
  • 4070 Answers
SOURCE: fabric conditioner still in compartment after wash
Most washers recommend dilluting the softener with water when you put it in the compartment. It can build up and completely block it. I've had to manually remove it with anything I could find to reach it and since I've started dilluting it have had not problem.
Posted on Aug 27, 2009
Testimonial: "Advice worked a treat. "
bozcro
  • 867 Answers
SOURCE: Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Posted on Dec 11, 2009
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Fabric tray does not clear
Usually means soap dispensing drawer needs to be cleaned, as conditioner is dispensed by syphoning system, Take out soap detergent drawer, clean thoroughly in warm water, make sure drain hole in conditioner compartment is clear.
Nov 20, 2011 | Washing Machines
Where to put soap powder in Diplomat 8512. There are three compartments in the dispenser drawer.
it goes in the iddle one, the right hand one is for softner and the left is for pre-wash. hope this helps.
cheers
iain
May 03, 2011 | Washing Machines
I have a Whirlpool Duet and the water is over flowing from the soap drawer. I have already cleaned out the soap drawer and tried flushing the opening that leads into the machine with a hose. Any other...
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener drawer filling with water
lift out the blue part of the conditioner compartment and you'll see attached a tube at the end.
clean this out completely.
also check the tube in the compartment is clear.
poke a cotton bud down it to clear it.
if you want to check to see if its worked take the drawer out(blue button at back of drawer) put the blue grid back in the dispenser and fill the compartment up under the tap ,hold the drawer level.
as it gets full you should see water start to flow out the back ,turn the tap off and if its worked the compartment will slowly empty.
these were a big problem for hotpoint and concentrated conditioners will block it regularly.
Jan 17, 2010 | Samsung Washing Machines
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Water comes out of detergent drawer
Aug 13, 2009 | Samsung Washing Machines
My Washing Machine is emptying the Fabric conditioner too early
Washing Machine has started to empty the Fabric Conditioner high water or blokage in draw
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 05, 2009 | Washing Machines
Compartment 3, detergent dispenser, fabric softener.
Grasp the drawer firmly, and give it a good tug to pull it out.
Remove all parts, and thoroughly clean, then just line it up with compartment and push it back in.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
593 people viewed this question
Top Washing Machines Experts
