Dishwashers Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The door to my dishwasher opens too easy now. Like it falls down too fast. what can I do to fix it?
Anonymous
Level 3:
  • Dishwashers Master 43,501 Answers
  • Posted on May 12, 2011
Anonymous
Dishwashers Master
Level 3:
Answers
43501
Questions
0
Helped
10834159
Points
101584
A spring or a rope broke that holds the door...they are on the sides of the door to help support it..
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
4helpful
Falls open when? This unit wom't operate unless the door is secure so I assume you mean the door assist springs are disconnected or broken and the door just falls heavily to the open position after you unlatch it from the closed position. Try these, part 18 here
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI01FLSS3/0593/0130000/W0503111/00007
should attach to frame in an easy to distinguish hole or slot and to door hinges, number 2 here
http://c.searspartsdirect.com/lis_png/PLDM/W0503111-00001.png
Something has happened to the door of my dishwasher when you open it it falls down heavily and now when I put the dishwasher on the door keeps opening
The door springs or ropes have broken...
heatman101
Mar 16, 2011 • Dishwashers
2helpful
2answers
Door falls open
The side spring springs could have unhooked. Some springs connect to a nylon rope that slides over a plastic guide. The rope could also have snaped or slipped off the guide. You need to open the sides (normaly the back first) to check. This is easy to fix if you have the right tools...
2helpful
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
2answers
Heavy dishwasher door that falls open
I think any parts person would recognize it by that name.
It's a fairly simple fix.
The one you have may just be loose on one end and not broken -- check that before you buy one.
May 06, 2009 • Dishwashers
The door to my dishwasher swings open to fast
You will need to bring the DW about 8-10 inches out from under the counter to access the door springs on the side of the unit.
Any questions, let me know
Please take the time to give this solution a fix ya rating
clarkco
KitchenAid Dishwasher KUDSO2FRSS
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Kitchaide Dishwash Door
There is normally 2 heavy springs & cables that control the "falling" of the door located in the bottom of the machine or it the door itself. Sounds like one (or both) have snapped.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
