Question about Kwikset Professional Door Lock installation Kit
Kwikset powerbolt 1000 keyless entry deadbolt lock with keypad
I cannot lock the door using the key. I can use my key to put the door in the locked position but when I reverse the key a quarter turn to pull the key back out, the key won't budge. The only way to remove the key is to unlock the door again.I cannot lock my door.HELP!
  • Anonymous Jan 15, 2009
    Bolt seems to be extending far enough - did I install it wrong?
  • trieber May 18, 2009
    just installed a taymor keyless entry deadbolt. when you use the key it works beautiful, except for one thing - the key cannot be removed unless it is in the unlocked position. also the keyless entry will only work when the key is in the keyhole. if the key is removed it won't work (sounds like it is getting stuck). any ideas?
  • 38 Answers
Make sure that the bolt hole on the jamb side is recessed enough so the bolt gets a full extension. Without this externsion the bolt will not engage the key release. So when you do your quarter turn you are actually turning more. Remove the strike plate and drill the hole deeper until the bolt can extend all the way. Also double check your key to make sure it is not spurred or worn.
Posted on Sep 11, 2008
SOURCE:
New deadbolt notworking?
You have the lever that goes from the key cylinder part of the lock through the striker portion of the locking assembly turned part way, either in the wrong direction or not turned enough in the right direction so if you take the inside portion of the lock off and pull the outside portion out of the door and rotate the lever to its proper position and then put if all back together in the correct sequence it should work properly.
Sep 19, 2014 | Schlage Aged Bronze Grip Handle Entry Set...
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
2001 hundai accent cannot unlock car doors with key. It worked on doors lastmonth. Have used lock deicer, wd-40 to no avail. Key works in ignition & trunk.
dose the key turn in the lock you could have a worn door lock where the plastic link bar on the back of the barrel gets a bit worn and just dosnt pull the link bar up enough , you realy need to remove the door pannel and really look at whats happening to the lock from inside the door checking the movement when you turn the key to unlock position you may even take up any play on the link bar to the latch lock by putting a slight bend in the bar to take up the slack
Apr 09, 2013 | 2007 Hyundai Accent GLS
Battery is DEAD on 2003 Ford Escape! Door key (using an actual key) unlock is also motorized, which needs battery juice. I can't get into this car! I thought about putting jumper cables on the sta
Open the door manually with the key!
Many Ford Escapes have power door locks as standard equipment. This system consists of a lock switch, lock actuator and wiring harness. When you depress the lock switch, it sends an electronic signal through the harness to the actuator. The actuator moves an internal piston that either pulls the actuator hook down or pushes it up. The actuator hook connects to the lock rod, which either locks or unlocks the door, depending on which way you push the lock button. While this system won't work with a dead battery, the mechanical lock system remains unaffected by electrical power loss.
Insert the door lock key into the driver's door lock.
Turn the key counterclockwise one quarter turn.
Pull the door handle up until the Escape's door opens. Once the driver door is open, simply open the remaining doors by pulling the interior door handles until the doors open.
Aug 13, 2017 | 2003 Ford Escape
Just installed keyless entry lock. Lock button works fine, enter code and deadbolt only partially retracts. Worked fine the first time, will not completely unlock since. Key works to fully unlock. Tried...
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Oct 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I forgot the code and I lost the key
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Aug 03, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
How do I errase the code and reset a new code on my kwikset powerbolt keyless entry door look
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Jul 05, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
HOW TO TAKE LOCK OUT OF GLOVE BOX DOOR HANDLE?
Hello, to take lock out of the glove box door handle you have to follow these steps:
1. You have to open the box door.
2. Push latch to close position
3. Put in lock position and remove the key
4. Push in tab
5. Insert the key
6. Turn the key to unlatch the position and pull lock out.
7. If latch needs to be replace, UN-screw collar
8. Reverse to re-install .
Thanks
Jun 29, 2011 | 1993 Chevrolet Caprice
Kwikset Professional Door Lock installation Kit Logo
1,279 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Thomas F. Schneider
Marvin
Marvin
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
