Question about Acer Aspire 5315 Notebook
Touch pad Hi there, Please bear with me (I?m not technical at all!!) Right, I?ve got the above notebook and the touch pad seems a bit lively, for example, when navigating around the page (i.e. dragging the cursor) it seems to highlight and drag what ever is on the page similarly it clicks on any url's I make the mistake of hovering over. also when typing, the curser will jump from the word I?m writing to the beginning of the same sentence or out from the navigation bar into another section of the page. Can you help me - maybe there are some settings I could change? Thanks for your help. Martin.
  • 1 more comment
  • martinkeeton Aug 13, 2008
    I have only had the laptop for a week, i ran the Norton Full system scan yesterday (took about two hours) it did not flag one single thing that needs attention.
    i maybe should mention that i use mobile broadband - could that be anything to do with the problem, (i guess i should try using the touch pad whilst not connected to see if the problem persists)
    Would using a mouse resolve it do you think?
    'Have you gone into the control panel to see if you can calibrate the touch pad at all?'
    I guess this is a start/settings/controlpanel/
    Where would i look once i have got this far?
    (im not using the laptop at the moment - im on my offce desktop)
    Thanks for all you your help - greatly appreciated.
  • martinkeeton Aug 14, 2008
    Just wanted to say thanks for the help,
    I got home yesterday and went to the setting - i turned of the 'Tapping' facility, this has fixed to issue i had, now the cursor will only grab, drag, click, if i use the left click button.
    Thanks again!!
  • 2,794 Answers
Run an anti virus program in the computer and see it there is programs on your computer such as viruses or potentially unwanted programs causing this problem to happen.
Posted on Aug 13, 2008
  • Tim Babcock
    Tim Babcock Aug 13, 2008
    Unless the pad is bad on it. If you plug a mouse in and it's going away, then perhaps the drivers should be reloaded for the toch pad.
  • Tim Babcock
    Start. Control Panel. Mouse. The controls should be adjusted in there.
Touch pad not working light bar not on above the touch pad
Hi Cheryll,
Make sure there are no problems with the driver installed on your machine by going to Control Panel->Device Manager and see if there are any question\exclamation marks on one of the drivers. While you are at the device manager you can check the touch pad driver version and update it to the latest from the manufacturer website if needed. To check the driver version double click the touch pad and go to the Driver tab. You will see it under driver version.
Also some netbooks got an hardware button to shutdown the Touch Pad.
Regards,
TheSmacker.
Jan 21, 2014 | Toshiba Satellite A205-S4617 Notebook
My touch pad not working probably .
Adel Heider,
You may want to first download the driver and install it into the system from the link below.
Inspiron 1545 Drivers Download Page
http://dell.to/14IpAJU
Erratic Pointer Movement
Here are some easy steps to take to determine the problem with a touch pad demonstrating erratic pointer movement:
  1. Get the latest driver from support.dell.com - Most problems can be corrected with a simple driver download. This should always be one of the first steps when diagnosing any touch pad problem.
  2. Check for hand and finger placement - The most common cause of random pointer movement is that the touch pad senses a finger or part of the hand near the surface of the device.
    • Have the customer attempt to use the touch pad normally but to pay attention to the location of his or her hands and fingers. Are any straying too close to the touch pad?
    • Adjust the Touch Sensitivity and TouchCheck settings in the Touch Pad Settings section of the Dell Touchpad Properties.
  3. Try an external mouse - Does this problem happen with an external mouse attached?
    • The Device Select section of the Dell Touchpad Properties has options to enable or disable the touch pad or external mouse. Try several combinations of these settings.
    • If the problems only occur when the touch pad is enabled and do not occur any time a mouse or other external device is used, then the issue is related to the touch pad.
  4. Check for mechanical problems - If the problem cannot be corrected by adjusting the settings mentioned above and only occurs with the touch pad enabled, then this could indicate a mechanical problem.
    • Press down on the palm rest on first the left side of the touch pad and then the right. See if the cursor starts moving on its own.
    • Run Dell 32-bit Diagnostics and try to recreate the problems there. If either of these situations occur, then replace the palm rest.
No Pointer Movement
No pointer movement from the touch pad (or track stick, if available) usually is the result of one of two things: The touch pad has been disabled in the driver interface, or the touch pad cable is damaged or disconnected. Follow the steps below to determine the problem.
  1. Connect an external mouse - In either situation, an external mouse should still function. If it does not, try booting into Safe Mode and testing both devices again.
  2. Enable the touch pad in the driver settings - Using the external mouse (or key strokes if no mouse is available), go into the Dell Touchpad Properties. Go to the Device Select section and enable the touch pad. If already enabled, get the latest driver from support.dell.com.
  3. Test the device in Dell 32-bit Diagnostics - To eliminate a potential software problem, run the Dell 32-bit Diagnostics and test the device here.
  4. Check for mechanical problems - As a last resort, press down on the palm rest where the touch pad connector is located on the system board. If the pointer reacts in some way, then the cable may just need to be reseated. Otherwise, replace the palm rest.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 07, 2013 | Dell Inspiron 1545 Notebook
My Keyboard and Touchpad are not working
Try installing your Windows again.A bit hard to tell, cause it can be allot of things that went wrong..
Oct 23, 2011 | Computers & Internet
Hi please help. i installed windows 7 on my laptop and the touch pad scroll does not work. I downloaded all possible drivers from Sony's official site, but no success. Help please. Thanks
What you need is not just the driver but the "Synaptics" software. This software enables gestures for laptop touch pads including scrolling. They are located here: http://www.synaptics.com/resources/drivers
32 bit: http://drivers.synaptics.com/Synaptics_v15_2_20_C_XP32_Vista32_Win7-32_Signed_Marketing_SGS94_UI-Scrybe.exe
64 bit: http://drivers.synaptics.com/Synaptics_v15_2_20_C_XP64_Vista64_Win7-64_Signed_Marketing_SGS94_UI-Scrybe.exe
Sep 26, 2011 | Sony VAIO VGN-NS190J/L 15.4-Inch Notebook...
Acer touchpad not working
Hi thre can you please check the touch pad mode? May be its disable some how. Or try to press FN+ F7 key for enable / disable touch pad. What is happend please let me know. Thanks.
Mar 18, 2010 | Acer Aspire 3680-2682 Notebook
Code f 21
CCU/TOUCH-PAD/LED ASSEMBLY ERROR. this error occurs if the touch-pad/led assembly is not able to tranmit/receive data to/from the central control unit (CCU) 1 check the touch-pad/led assembly by selecting different cycles and changing the modifiers and options available to cinfrim the touch-pad/led is responding. 2.unplug washer or disconnect power. 3.check wire harness connections to the touch-pad/led assembly and central control unit (CCU) in the back of the washer there should be 3 or 4 t20 torque bits there star looking bits the screws are above the water vavle take those out then pull it towards u and the CCU is right there in the back on the top u cant miss it or its might be on the side good luck scott8326@hotmail.com
Feb 17, 2010 | Kenmore Elite 45986 Front Load Washer
Touch pad doesn't seem to work and dosn't come up
HI,
TOUCH PAD DOESNT WORK,IF U R TECHNICIAN OR FAMILIAR WITH ELECTRONICS,SO DESEMBLE LAPTOP AND SEE WHETER STRIP OF TOUCH PAD IS CONNECTED TO MOTHERBOARD OR NOT.
TNKS
RABBANEES
Nov 04, 2009 | Dell Inspiron E1505 Notebook
My HP Mini touch pad is locked up. There's a red light right above the touch pad that is usually white.
on the new hp mini - you double tap the touchpad indicator (upper left) to toggle the touchpad on & off
Oct 30, 2009 | HP 2133 Mini-Note Notebook
MY SCROLL DOESNT WORK ON MY TOUCH PAD
this may be unfortunate, but it's plain and simple. Either SYNAPTICS POINTING DEVICE which can be found 'C:\Program Files\Synaptics\SynTP' on your laptop i corrupted or infected, or your touch pad is buggered. Hope this was of some help and if you have anymore problems just post them.
Regards,
Vistapro
Mar 26, 2008 | Toshiba Satellite L10 Notebook
Enabling computer mouse
did u hit fn key or botten above mouse turn the mouse on ??> buy usb one mini
Jan 16, 2008 | Toshiba Qosmio G25-AV513 Notebook
Acer Aspire 5315 Notebook Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
