Transcend USA 120GB Storejet 2.5" SATA - Titanium 120 GB USB 2.0 Hard Drive Logo
A
Anonymous Posted on May 12, 2011
I bought usb flash drive JF V30/32GB when i copy files n folders only 5 to 6 picters can b open rest of them r corrupt wen i right click on files i can see the size of each but im not able to open them
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on May 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
4590
Points
25
Hello, i have a Transcend JF V30.. that after when i copy a file folder with a capacity of 4.80GB to the flash drive, and when i open the files in it, some files aren't copied. But still its 4.85G
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
tip
MultiBoot USB Flash - Survival Guide
Grub4DOS is a boot manager
that can be easily installed to a USB flash.
It allows booting multiple operating systems
from a simple graphical user interface.
1.) Format the USB flash drive in the FAT32 or NTFS filesystem. (Windows)
Download and start HPUSBFW.EXE )http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
-REMINDER!!! all data will be deleted on the USB flash-
1.a) Download necessary files
Grub4Doshttp://dl.dropbox.com/u/4040651/grub4dos-0.4.4.zip
Grub4Dos gui Installer 1.1
http://dl.dropbox.com/u/4040651/Grub4Dos%20gui%20Installer%201.1.rar
1.b) Extract the downloaded zip files into separate folders.
For example:
Grub4DOS to C:Grub4DOS
Grub4Dos gui Installer 1.1 to C:
2.)
If your flashdrive is not already plugged into the computer, plug it in now.
2.a) The next step is to run the Grub4DOS Installer.
Browse to the Installer's unzipped folder using Windows Explorer.
2.b) Run the grubinst_gui.exe program (Windows XP)
Right-click on grubinst_gui.exe Run as administrator (Windows 7)
2.c) Once the program is started, select the Disk option,
then click the Disk Refresh button and then select
your flashdrive from the dropdown box.
IMPORTANT:If you accidentally select the wrong drive,
you may not be able to boot your system without doing a boot repair.
2.d) Now click the Part List Refresh button,
then the dropdown box and finally select the Whole disk (MBR) option
2.e) Click the Install button to install Grub4DOS to the MBR
of the flashdrive.
Hopefully, you'll get the message that the installation was successful.
3.) The next step is to copy the grldr file to the flashdrive's
root folder.Using Windows Explorer, browse to the folder
where you unzipped
the Grub4DOS program and copy the file to the flashdrive.
3.a) Grub4DOS is now installed on the flashdrive.
4.)Download file
menu.lsthttp://dl.dropbox.com/u/4040651/menu.lst
4.a)You need to copy the menu.lst file to USB Flash
4.b)Create a folder Boot on a USB flash drive.
in this folder create new folders
Splash
menus
4.c) Download file
Snaiyahttp://dl.dropbox.com/u/4040651/Snaiya
4.d) On USB flash-open the folder Boot
Within-we see Splash folder. Copy the file Snaiya into it.
5.) Add Puppy Linux on a multiboot USB flash
5.a) Download the Puppy ISO imagehttp://www.puppylinux.org/
5.b) Create a folder Puppy on a USB flash drive.
5.c) Take from the downloaded ISO, file
PUP_420.SFS (from the folder Puppy)
Rename it to pup_420.sfs
and copy it to
USB flash.
5.d) Copy all other files from the downloaded ISO (from the folder Puppy)
to the folder /Boot/Puppy/ (Create a folder on a USB flash)
5.e) In the menu.lst add a:
title Puppy
kernel (hd0,0)/boot/Puppy/vmlinuz ramdisk_size=100000
initrd /boot/Puppy/initrd.gz
5.f) Preserve the changes and now menu.lst looks like this:
gfxmenu (hd0,0)/boot/Splash/Snaiya
timeout 30
default 0
title Puppy
title Boot from CD-rom
cdrom --init
map --hook
chainloader (cd0)
title ShutDown PC
halt
title Reboot PC
reboot
5.g) Puppy on our MultibootUSB flash-is ready for operation.
(Now we can restart our computer and see how it looks and works)
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
on Feb 07, 2011 • Computers & Internet
2answers
I want to copy music folders to the 8gb sahara usb flash drive but is saying I cant is the drive is protected
click start all programs accessories open windows explorer navigate to your music files right click on the music right copy navigate back to the destination drive right click select paste or hold the
mouse cursor on the music files drag them to folder
then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another
device floppy or a usb device
if you need more help with this post a reply
hope this helps
2answers
I have just purchsed a 4gb usb2 flash drive . I am wanting to copy some pictures from my desktop and put them on my new laptop . Can anyone tell me how to do this in simple language as i do not understand...
Hi. All you have to do is:
- Insert your new USB flashdrive in an empty USB slot in your desktop computer.
- A new window will appear and will ask you what you want to do with that device... Choose "Open folder to view files".
- Then just leave it there and go to the file(s) you want to copy, right click on i and click "copy"
- Go back to your USB folder, right click on an empty space on that folder and click "paste". That will copy the files into your USB flashdrive.
- Remove the USB flashdrive from your desktop.
- Insert it into your laptop's empty USB slot.
- Highlight all the files you want to copy from USB flashdrive folder, right click and click "cut".
- Go to your laptops folder where you want to copy the files, right click on an empty space and click "paste".
Thanks for using Fixya!
3answers
Dont know how to tranfer from pc to sandisk
Go to My computer and it should say something like Removable disk ( :h) , click onto it and thats whats inside ur USB, to transfer copy and paste the folders or just Move then to your removable disk
hoped this helped :)
1helpful
6answers
HOW DO I copy a file on my document to my flash drive
There are a couple of ways to the this.
1. you can right click on the file and select copy then select your flash drive and right click inside the folder you want to place it and select paste.
2. Open your flash drive and your my documents folder and click & hold the file you wish to copy and (while left click and holding) drag the file to your flash drive
3. If you have the file open you can save as and select your flash drive as the location to save it.
Youtube clip here (not mine): http://www.youtube.com/watch?v=UkOVz32z51U
2answers
How to copy a doc. file to the flash drive.
Ok. here is what you need to do.
1. Hook your flash drive to any of the usb slot in your computer.
Wait for the system to read it. A green arrow icon will appear in the taskbar to show that a new removable hardware device is connected. After it successfully recognized, It will display a message " The device is installed and ready to use" at the lower right portion of the windows taskbar.
Click on My Computer a new drive will appear. It is usually designated as removable drive. On this drive you will paste the copied doc files. It is the assigned drive for your flash drive.
So go on., copy all the files you need to carry and paste it in the flash drive.
Be reminded also that before you unhook the flash drive from the computer, right click first on the green arrow icon on the taskbar and stop the operation. Click stop on the flash drive. This will turn off the remaining applications / readings in the flash drive and will prevent it from crashing and file corrupting.
I hope you understand.
Please give me some good ratings as this will help me too.
Thanks.
2answers
I just bought a PNY 4 GB High speed usb 2.0 drive I would like to put my pictures on it how do I do it? from my computer.
Insert the USB drive into any USB port of your computer. When you do, you should see a window pop up that asks what you would like to do now. Click the option to browse the files. You should now have a window open for your USB drive. Next, open up my computer and find your pictures on your hard drive. Once you have found them, you can click and drag the pictures from the hard drive window to the USB drive window. Do this as necessary for any or all the pictures.
Wen i copy files or data, few gets copied and the rest doesn't.
Hi rijo_frendz,
Format the USB drive. Then create a folder on it and copy your files into the folder. It should be working now.
Kingston Tech Support
4answers
Computer keeps on telling me "please insert a disk into drive E:"
try to rerfresh on MY COMPUTER then it will appear on E, if it won't open, right click then Explore.
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
k24674
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
