My monitor's blue on light blinks at second intervals. I have consulted the manual which deems this as a sleep mode poblem. I followed intructions: 1. pressed any key on the keyboard 2. Pressed the arrow icon on the monitor then pressed any key 3. Checked all the cables, ports and outlets 4. turned the power both on and off of the monitor and computer - all to no avail. Can you please help?
You can enter or leave the "Sleep mode" by tapping the Flex rapidly for 1-2 seconds. You'll feel a vibration and the LEDs will blink. (The blinks will depend on if you are entering or leaving sleep mode.) In this mode, the Fitbit Flex reduces the LED intensity and doesn't give alerts. Afterwards, it will provide some data about your sleep pattern - length, movement, waking up during the night. This can help you determine the quality of your sleep. (Note: it isn't a replacement for consulting a doctor if you always wake up tired.)
I hope this helps.
(You can manually enter your sleep and wake times into the app without using "Sleep mode". Then the app will use the movement data from the Flex to determine sleep quality. However, LED lights (primarily blue frequencies) are known to reduce sleep quality so dimming them helps most people sleep better. The alerts will also interrupt your sleep and reduce the quality.)
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
dont know how old monitor is but it may be time for an upgrade OR the pc/laptop/desktop? may need some setting changes for your wake time, sleep time, intervals, etc.? Sometimes if laptop,, you have to tap the power button to wake up after extended sleep times.
You need to try it on another PC, alos verify if the VGA cable is good. If nothing change, then you need to open it up, first thing to look for are the capacitors in the power supply. Look for cpas with bulging top/seal, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
