Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 43VJ22P Screen is very hazy, hardly can see any picture. What is the solution to get the sharp pictures. I have tried convergence and setting the lamp as well but nothing worked.
TOSHIBA 43VJ22P I HAVE NO PICTURE BUT THE RED LIGHT IS ON.. HELP
Posted on Jan 20, 2009
SOURCE:
Hi, I have a toshiba projection colour tv model number 43vj22p, the picture has a shadow as the plates inside are not aligned, i cannot manually alter them so need to know what I should do, do I ned a...
I am sorry to say that it is a highly specialised job, re converging these so Yes you do need to call an authorised Toshiba Repairer.
Hope that answers your question.
Dec 14, 2010 | Toshiba Televison & Video
Hazy and messed up color
Ur tv convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 22, 2010 | Hitachi 50UX57B 50" Rear Projection...
Toshiba 43VJ22P convergence trouble! I have a Toshiba 43VJ22P, the red convergence was out in the x plane, and could not be adjusted, however it could be adjusted in the y plane. So i've changed the...
Hi
Thanks for using FixYa. Then it means the problem is with the convergence board and it’ll require to be replaced to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 26, 2010 | Televison & Video
Toshiba Model 43VJ22P Shadows on the screen? Adrian
Ur convergence is dead.Must replaced these 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and labors.
Feb 02, 2010 | Toshiba 42H81 42" Rear Projection...
Toshiba 43VJ22p rp tv has lost bottom half of picture and has bad convergance but is impossible to read menus to adjust settings, no obvious component issues or wiring faults, any ideas?
the redgun of my toshiba 43vj22p is out of focus, so much that i can't adjust it anymore. does this mean i have to change the lamp or is it something else?.
Nov 05, 2009 | Toshiba Televison & Video
48" rear projection hazy/bad picture
most fluid changes would fix that. I recommend doing all three but that's just me. Also make sure the crt's are full as this would cause the set to be out of focus. also make sure you don't move the yokes too much because you can knock the convergence out pretty bad and also have a blurred pix
Jan 09, 2009 | Televison & Video
Shadows on Rear Projection TV
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Televison & Video
Toshiba model 57H81
If you have zagged lines there are 10 small surface mounted capacitors you will need to change on the HYper Board. This is not an easy repair so alot of folks simply replace the hyper board. You will need a service manual to take this set apart and to get the proper part number. If you have no TV repair experience or do not know how to solder, as the hyper board has sheild arounfd it, you should play it safe and call out a pro to assist you in this repair. Good Luck
Mar 19, 2007 | Toshiba 57H81 57" Rear Projection...
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Toshiba 57H81 57" Rear Projection Television Logo
253 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
