Can connect home PC to Netgear DG834 ok (wireless and LAN) but can't access any internet pages. Router LEDs suggest the external connection is also ok. Could this be TCP/IP issue with PC or possibly firewall issues? Help...
  • KH001 Aug 13, 2008
    Makes no difference whether wireless or cable - cannot access internet pages with either method. It's the same for other laptops in the house with wireless connection.
    Will check firewall as I think other half may have installed Norton IS fairly recently...
  • 320 Answers
How you connect cable o wireless if using wireless check firewall and mac filter
Posted on Aug 13, 2008
  • IT aid
    IT aid Aug 14, 2008
    have your router got connection with internet??
SOURCE:
Using Netgear DG834 ADSL Modem, want to add a netgear WNDR3700 Wireless Router to act as an assess point
The simplest way to add more ethernet ports is to use a network hub and connect it to the Netgear DG834 instead of the Netgear WNDR3700. This does not require any configuration.
Mar 08, 2012 | Apple MacBook Pro Laptop Computer with...
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
I have a netgear router but when i switch it on the internet light is always red and i cannot connect to the internet on my laptop
Try RESETTING your Netgear back to the default settings and configure it again.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 02, 2011 | NetGear DG834G Router
Was disrupted wiireless connection with my lop top,It still working just trough cable connection.Pasword did not accepted.I use Virgin media as internet customer but thay home service is not helfull.How i...
http://192.168.0.1
The default PW = password You can now change the default password.
You can now change the admin password and configure the wireless settings.
Now apply these wireless settings to the wireless card in your computer
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Apr 22, 2011 | NetGear WNR2000 Wireless Router
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
I can not connect my Netgear router to my computer though ethernet cable also could u tell me what a WPA key is please.
Hi Kelly, Connecting the router with cable is fairly easy and hassle-free. All you have to do is connect the router and PC using CAT5 or CAT6 Patch cable and the internet should work if the cable is fine. It is indicated by the corresponding LED on the router and LAN port LEDs of PC. WPA Key is the password required to connect wirelessly to the router. User Guide for NetGear WGR614 is available for reference.
To secure the router, first you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually 192.168.1.1 or 192.168.0.1 and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password password.)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA or WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key (WPA) to access the internet.
Feel free to contract me for further assistance
CreativeTECH
Dec 28, 2010 | NetGear WGR614 Wireless Router
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
I just set up a netgear router and a lynksys expander. All my laptops work, but iphone & itouch will not. Seems as though the password has changed. Can this happen? How can I find the password? When I...
If you did not configure the Netgear wireless router and changed the default settings and the default password password, then your wireless system is open to anyone hacking into your system and change your wireless router's settings and they can hack into your computers and your Internet connection. The Linksys expander will increase the wireless range to give a wider coverage to your router.
I suggest you reset the Netgear back to the factory defaults (press the pinhole button on the back of the Netgear router until the LEDs flash then release this button,
The configure the Netgear as follows :-
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
No internet when router plugged in
I assume your modem is a ADSL or cable modem.
I suggest you first connect your modem to a computer and check if you can connect to the Internet. If you cannot connect then check status of the LEDs on your modem. If you don't have LEDs indicating the PPP/ADSL, and LAN connection then you have an ISP connection problem.
If you can connect to the Internet then your problem is either the router configuration and or LAN configuration.
Jun 15, 2008 | NetGear WGT624 Wireless Router
Open Questions:
bxshhj AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 20, 2019 | Amazon Computers & Internet
^%#@*& Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Computers & Internet Logo
41 people viewed this question
Ekse
Alun Cox
