Question about Intel Motherboard
Starting computer my computer does'nt show anything when i turnned it on even my motherboard bios. The screen appears blank.
Sorry to Hear That. do you have a graphics card if so carefully take it out and put it back in, then try again. if the system doesn't com on move to the memory sticks if there two remove both and only use one to see if the system comes on. final once the system lights are on the processor is the final arrear some times this can be the problem good luck.
Posted on Aug 13, 2008
Aspire 7250-3821 white screen only
Have you tried with a external monitor, if that works the gfx card is ok and fault lies in a connector that has released from the motherboard. The lcd isn't getting the signal from gfx card wich only can be the connector or the control circuits(matrix circuits) for the display the latter example requires a new screen.
But if the external monitor doesn't show anything it's the graphics card mounted on the motherboard that has given up and that isn't something can be fixed without replacing the motherboard.
Jan 25, 2013 | Computers & Internet
My computer won't start. when switch on it beep once and power comes but blank screen and stay that way, nothing happens. pls help thanks
Hmmm.. are u using an LCD monitor?
Did u try to use another monitor?
Even on start up, the BiOS didn't show up?
Tell me more...
Dec 03, 2010 | HP Pavilion dv2000 Series Laptop Full...
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
I added a Pentium P4 2.66Ghz cpu 533FSB, Bios appears and says the due to new cpu installed system has started at 64Mhz please select correct Frequency. I select 2667 Ghz and 133Mhz saved and restarted....
Turn the computer off.
Turn the computer on.
Wait a minute or two -- it may "time-out" and reset it to the "slowest" speed.
If that fails, look closely at the motherboard,
or read the manual for the motherboard, to find a "clear BIOS" jumper.
Turn the computer off. Move the jumper from "1-2" to "2-3".
Wait a few seconds. Move the jumper back to "1-2".
Turn the computer on, with the "default" settings.
Oct 28, 2009 | ASUS P4S533-MX Motherboard
Blank Screen
First, confirm that it is the screen itself. Connect the video output to a known working monitor and then power on your Thinkpad. if the known working monitor behaves the same way you can rule out the laptop's monitor as the source of the problem. This may be the BGA, Ball Grid Assembly, leadless soldering problem related to video chips on the motherboard, but first test the monitors.
Apr 15, 2009 | IBM ThinkPad R51 Notebook
Blank monitor screen
It appears that this motherboard has an on-board video port, I would recommend unplugging the video card and try using the on-board video. Make sure that when you do this, the BIOS POST screen shows, if it stops making the beeps, but still doesn't show anything, you might want to reset the BIOS (using the on-board jumper, sometimes also displayed as CMOS reset or password reset). If it still beeps, it might be the RAM, and you might want to see (if you have more than one stick of RAM) if you can try unplugging one or the other, or even switch their locations. Good Luck.
Mar 25, 2009 | ASUS Computers & Internet
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Wont startup
1.may be the smps(power supply) not be proper.check power supply......
2.processor may be corrupted
3.bios cell may not be working proper
Dec 15, 2007 | Intel Motherboard
Intel Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
