Will the pump spray work without the vacuum being on? If so Listen for the pump spray motor. If you can hear it whining then you may have something plugged like a hose or the hole at the end of the hose, also make sure the filter in the water reservoir is not plugged. Maybe the Impeller is bad in the pump motor.
If you don't hear the pump motor then you may have a bad motor or the button you push/pull could be bad or the wiring harness may be bad. Good luck
Sounds like you have an ignition issue, bad coil, or bad signal from a sensor or something. There are 3 things to check to make an internal combustion engine operate, 1. Engine Mechanical, make sure that your engine has enough compression to run, it needs at least 100psi,
2. Ignition, all sensors good, battery good, all switches work correctly, etc. 3. Fuel / Air. If number 1 and 2 are good, then worry about fuel delivery. You may want to find someone that works in the power sports field to take a look at it,
Hi,what is your mobile model? you can unlock your mobile by unlock codes..the safe and best way of unlocking is by unlock codes and my personal request is that don't go for software unlocking because sometimes the software might get corrupted and may your data will be lost due to that,its my bad experience so I went for unlocking by codes from here mobileunlocksolutions and unlocked.you can too try but see to that whether your country and provider is listed..because for some service only codes are available..check with that and if your country's provider is listed then get codes and unlock your blackberry..before unlocking your mobile you can get clear instructions about how to unlock your mobile for that you can visit mobileunlockguideto get step by step instructions..
my phone is gfive u 909 . iforgot my phone lock code. it is asking the code when i switch on the mobile . please help me......... my email address [email protected]
