Question about Philips DVDR3450H DVD Recorder/HDD Recorder
Picture/Sound freezes I have a new Philips replacement DVDR5590H and of the 3 replacements I have had they all have started to freeze picture and sound for 2-3 seconds.This has occured when playing back recorded programes off HD and those on the time shift buffer. This recorder is only 2 weeks old and has started doing this as did the last one on May 2008 and one in June 2007 >THis is the latest model in NZ but the one below was doing exactly the same
  • 1 more comment
  • tigtag Jan 11, 2009
    I got the same problem! I don't know why? but it's for DVDR5590H.
  • hello_sailor Jan 21, 2009
    I have a DVDR5590H and yes, exactly the same problem has developed within a month of purchase.
  • Anonymous Feb 16, 2009
    exacly the same problem - totally ridiculous....
  • 8,596 Answers
This model does NOT work well with HD boxes. I would double-check the Philips website, and upgrade the firmware for device since all 3 players were doing same thing.
Posted on Sep 04, 2008
The picture freezes
It sounds that the main digital processor board has the fault. Normally this board has no repair other than replacement. After replacement, it will be necessary to update the firmware too. Contact any service technician, and make sure about the fault. If you're sound in electronics, check the link given here. It might help you. http://electronicshelponline.blogspot.com/ Pull up older posts there by its left sidebar.
Jun 14, 2013 | Panasonic TH-42PX75U 42 in. Plasma...
I have an HLR5057WAX DLP Samsung tv and my picture freezes often and the tv will sometimes power off. When it freezes it will stay that way for about a minute and usually turn back to normal. Lately I have...
The lamp is usually your first replacement, but a freeze in picture may have to do with the video board or the DMD board. Try the lamp first and see if that fixes it--because you'll need a new one anyway if you're going to keep the television. Make sure to get an OEM Philips lamp for your Sammy. Buy from an authorized distributor.
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Wii Freezing (Band Hero)
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aaa1
Jan 12, 2010 | Nintendo Wii Console
Several problems
you may want to check all of your coax conections and stray ground shield piece littl tiny silver mtal wire will cause that reaction or you may have a ad reciever if so if ou have the directv inurance they will replace it for no cost to you at all.
good luck
please rate
Jan 11, 2008 | Philips DSR708 DirecTV DTV Receiver /...
Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
Picture freezes Black/White
It's most likely the digital board, Samsung p/n# Bp94-00385a but I'd trace test both the digital and analog first before blindly replacing it - too costly to just guess..
Bill
Dec 08, 2007 | Samsung HLN437W 43" Rear Projection HDTV
Philips 55PW9363/17F
you get the distortion when the shredder is on because the shredder is sparking causing the interference. you can check your cables to make sure the have good grounding or just replace the cables.
Dec 03, 2007 | Philips 55PW9363 55" Rear Projection...
Philips DVDR3450H DVD Recorder/HDD Recorder Logo
175 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
