Question about Tecnik Washing Machines
Technik TK920 Hi i have a Tecnik TKL9290 and it wont spin or drain. Any dieas? However when the drum is empty and being tested out. It will spin?
Where can I get a teknik tk9290 waser dryer and are they special dimensions I need 59.5w 85.h 58d
Posted on Mar 02, 2010
    President:
  • 1,462 Answers
If no drain, then no spin
check filter and check for a foreign object stuck in the pump impellor
Posted on Aug 13, 2008
Hi my TKL9290 will not empty water I have tried to respin a few times but it hasn't worked could you please help
Hi Richard,
do you hear the drain pump coming on while spinning?
if yes, check if there's any water coming out of the drain hose.
if the answer is still yes, then you have either a broken impeller inside the pump, or something blocking it. Check the coin trap first if this is the case.
Hope this helps.
Jun 02, 2014 | Washing Machines
The drying process works through but no heat is produced. It was OK yesterday
Two options:
1- Heating element is dead.
2. Thermostat is faulty. this unit is normally located on the inner surface of the drum and can be easily accessed after removing the rear cover. It is normally installed in a rubber housing.
Good luck.
May 13, 2014 | Tecnik TKL9290 Front Load Washer / Dryer
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 23, 2009 | Washing Machines
After the mechine has been through its spin cycle and is slowing down it trips the power breaker
only the motor inside your machine for spin is defective, please check the may be need to replace the bearing.
Jun 12, 2009 | Tecnik TKL9290 Front Load Washer / Dryer
Washing Machine won't spin
Could be worn carbon brushes, or possibly defective shock absorbers
Mar 26, 2017 | Tecnik TKL9290 Front Load Washer / Dryer
Spin only on Tecnik TKL 9290
Prog 7 is cotton and linen cycle spin.
Prog 17 is delicates spin.
There is also a button to select fast or not so fast spin.
Sorry cannot help with online manual.
Sep 14, 2008 | Tecnik TKL9290 Front Load Washer / Dryer
Machine not spinning.
if its the motor you can hear the belts probably fell off but you may have mistaken the motor noise for the pump so if the belts on check the pump filter
Jun 29, 2008 | Tecnik TKL9260 Front Load Washer
Tecnik TKL 9290 / Washer Dryer
no drain then no spin check the filter and also if there is a foreign object jamming the drain pump impellor
Jun 16, 2007 | Tecnik TKL9290 Front Load Washer / Dryer
Washing Machines Logo
393 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
