What to do when camera falls down, and shows lens error 126,1,0,-13? when the camera fell down the lens were not closing [ not getting inside] even if we turn off the camera and displayed lens error 126,1,0,-13 . what should i do to repair it
Sorry but usually when the camera lens is forced shut, the gear mechanism will get out of sync. Usually even if it will open, you will receive a Lens Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
I am sorry to say that this is a problem related to the lens mechanism. The lens gears may have kinked/slipped when you fell down and this seems to be the reason why the lens cannot extend retrace. Unfortunately this is one repair that you don't wanna do yourself. The lens assembly has to be completely disassembled just to know the exact cause of the problem and any further damage means a new camera. Panasonic will charge you the cost of a new cam to fix it. So to get an estimate from your local camera tech would be the way to go.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism (look closely for sand particles around the lens barrel of your camera. A single grain of sand can jam in the gaps around the barrel, preventing the barrel from closing. Use air or a thin sheet of paper to dislodge them). Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
the lens
contacts are dirty - get a pencil with an eraser on the end, just
a regular old pencil with a red rubber eraser. Detach the lens from the
camera, hold it so that the lens’ gold contacts are pointing down and
lightly erase their exposed surface, cleaning them of any hand oil that
might have gotten on them.
Do the same thing with the gold contacts inside the camera body.
This is a bit harder but it’s doable: just hold camera so lens opening
points down so no gunk falls in. Erase lightly. I've used a lens cloth and
dabbed at the contacts rather than blow them so as not to blow the
erasings inside the camera. Works well for me....let me know how you fair!
