I used to repair monitor from Dell. There are 4 screws for rear panel and no screw for
front frame. If there is no visible screw, you have to look for
"capped" screw holes (little covers that fit flush with the case to
hide the screws). If you don't see these neither, this must be a tension fit case.
So, face the screen up and look for "rectangular hole" on the side
edge (usually at the bottom edge of the screen). You'll need a very thin flat screw driver and wedge
it into that narrow rectangular hole. You can use any prybar if you don't have
screw driver. It is not too deep. You may stab something important inside and
pry it. Once it starts to spread, start sliding it along the seem and you
should feel the tension tabs start "popping" open. Continue to work
your way around until it's off. The lamps should be located horizontally along the screen edge top and bottom. you might not see the whole lamps after opening the screen's back cover but you can pull it out from the lamp case. It has 2 electric wires connected to the end of the lamps.
Was this helpful?
Yes
No
Popular Solutions for IBM ThinkVision L170 17" LCD
I had lost my default settings (resolution) in my monitor -( IBM ThinkVision). I navigated to Image...
(More)
I had lost my default settings (resolution) in my monitor -( IBM ThinkVision). I navigated to Image Properties and selected OK button. Color option came. Then came PRESET MODE and CUSTOM. Then i clicked OK button. Here i lost my resolution. how do i get back my original values. Now the monitor is very bright.
when monitor start power led only one time on and after one second goes in off condition every time...
(More)
when monitor start power led only one time on and after one second goes in off condition every time happen when we switch on the monitor,monitor screen is totally black, g1 and g2 voltage not came heater voltage only 3v came at crt board.pl give me the solution about that
I think I have the wrong power supply. It powers up for a few seconds and flashes a picture for a...
(More)
I think I have the wrong power supply. It powers up for a few seconds and flashes a picture for a second and then it turns off and begins to flash the power light on and off continuously. I think it is just either a bad or the wrong power supply. What do you think?
unable to adjust resolution. currently using system monitor settings, I found no drivers installed...
(More)
unable to adjust resolution. currently using system monitor settings, I found no drivers installed for this monitor. after upgrading video card everything is displaying as if disability feature on largest size. have tried to increase resolution in device manager, when I move slide to higher level, and click apply goes right back
