Question about Epson Office Equipment & Supplies
Epson Stylus D120
Trying to set up printer with Windows XP. I have followed instructions as per disc.
Loaded the 4 ink cartridges, black, cyan, magenta and yellow. There is another slot for a 5th. cartridge. The instruction disc keeps telling me to load cartridge. I can not by pass this instruction and red light on printer keeps flashing.
Can you please help.
Thanks
  • Anonymous Jan 26, 2009
    ink is showing empty but they are full
Hi fitz ;
I have been reading up on this printer & think I know the simple answer .
Apparently what makes this printer so fast (for text) is it uses 2 black
ink cartidges . You need to fill the 5th slot with a second cartridge .
If U would like some links to the info just respond .
Good luck
Posted on Nov 11, 2008
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
Jul 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson sx210 inkjet printer trying to change black ink cartridge but can't find how to get print head to move to correct position to remove cartridge.
If you're using Windows,
XP : Click Start, go to Control Panel > Printers and Faxes Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Vista : Click Start, go to Control Panel > Hardware and Sound > Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
7 : Click Start, go to Control Panel > Hardware and Sound > Devices and Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have just changed all the ink's in an Epson d120
If you replaced with "genuine" ink-cartridges, then it should report "full".
If you replaced with "refilled" ink-cartridges, then the company that refilled forgot to "reset" the electronics inside the ink-cartridge, in order to report "full".
Or, perhaps, the software "toolbox" that came with the printer has a button "I have installed new cartridges, please re-verify the ink-levels" ??? Click that button.
Nov 27, 2009 | Epson Stylus D120 Network Edition ultra...
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
Jun 10, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Problem printing
1) Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 29, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
