Question about Philips Magnavox Learning Universal Remote
Philips universal Code
I am looking for philips universal CL034 code for LG Flatron and Memorex dvd player
  • Anonymous Dec 03, 2008
    I want to know
  • 2,071 Answers
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): Philips universal Code - clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 13, 2008
I have a philips universal remote control and i
I have a Philips Universal Remote CL034 remote and a Memorex MVD2040 also.
Hold [Code Search] until it the LED stays lit
Press [DVD]
0246 or 1606
0246 is the best code to use. For 0246, note that pressing
[Input / TV/VCR] = The all important DVD setup menu
Sep 21, 2009 | Philips Televison & Video
I need a philips cl034 universal remote code for memorex dvd play
I have similar problem with a Philips CL034 Universal Remote and a Memorex MVD2047. The Philips/Magnavox codes listed at this link did NOT resolve the problem. I tried all Memorex codes and tried the "all coded step-through" method. http://www.universal-remote.net/philipsmagnavox.html The above is NOT a solution, rather a note on a time consuming attempt to a solution.
Nov 12, 2008 | Audiovox 150W DVD Home Theater System -...
CODE
Try the codes from Philips: 0503, 0539, 0854, or 1914.
If those don't work contact Memorex support at 1-800-919-3647
Jan 06, 2008 | Memorex MVD2042 DVD Player
Lost code book
I can not find codes for my tv.
Jan 05, 2008 | Philips Magnavox Learning Universal Remote
Universal remote code needed
If you have tried all the codes the manual has it may be the remote does not support your model. Here is a lin to a remote I think will work on ebay:
http://cgi.ebay.com/Memorex-DVD-remote-control-MVD-2022-MVD-2042_W0QQitemZ280186652283QQihZ018QQcategoryZ91388QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You also can try another universal reote brand that might support your unit. Hope this helps.
Dec 27, 2007 | Memorex MVD2027 DVD Player
I NEED REMOTE CODES FOR THIS DVD RCA DRC200N
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
Oct 17, 2007 | RCA DRC200N
Universal remote
Which TV do you have? :)
Aug 28, 2007 | Televison & Video
Philips Magnavox Learning Universal Remote Logo
233 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
