HI there,
My name is steph and i'm a complete novice when it comes to computers! I want to view my digi photo's on memory stick. My laptop has the correct slot but nothing seem's to be happening?
Could you help?
Many thanks
Insert the memory card into a USB card reader and connect it into the USB port of your computer and also connect your memory stick into another USB port on your computer.You computer will detect both memory devices and you can click on them to open and view the files, then copy the photos on the memory card and paste them on the memory stick. If you have only one USB port then copy the photos from the memory card into your computer then connect the memory stick to your computer and copy the photos from the computer to the memory stick.
hi there.
1. just plug in your memory stick to a computer.
then a pop up like this will appear
e
2. Click the OPEN FOLDER TO VIEW FILES
3. on the next screen you will see this.... usually photos are stored in the IMAGES folder.
4. click the IMAGES folder
the next screen will show your photo list. So you can just click and drag the photos that you want to copy to your computer.
If your TV has ab USB port then you can copy the photos from your camera to your computer and the copy the photos from the computer to a USB flash memory stick. Then insert this memory stick into the USB port on the TV and select the USB input to display your photos.
Go to Start/ My Computer/ and check the camera card (not stick which refers to an external USB memory) It will be there named D: or E: open all the folders there one by one - also folders witthin folders - the photos have to be there.
You can use a USB flash memory stick. Plug it into the computer where the photos are located and copy the photo to the USB memory stick. Then remove the USB memory stick and insert it into the laptop and copy the photos from the USB memory stick to the laptop.
Don't know about cam (was there a software disk to install?).
As far as the reader goes you reader must be compatible with both devices. Hope this helps
More than likely the camera still thinks the photos are on the stick, especially if you deleted the images while it was hooked to the computer. I would safely move the rest of the photos off the stick onto your computer then format the card through the camera and with the camera disconnected from the computer. this should clear the card.
hey i have the same problem with the hp pavillion 6000. It is one of the most unreliable computers in the world but i guess thats another discussion... I have a 2g memory card that will only be recognized if i restart the computer and put it in then... Once you eject it though it wont recognize it. HP needs to get their **** together and stop ripping people off.
What model is it? Some have internal memory, many do not. If it does not have internal memory than you can only view pictures from your memory stick or card.
