When i tried to start my cell phone only a white blank flashed. Now the phone is totally dead (does not start at all) Also the battery is not getting charged when plugged. i tried to update it from official SonyEricsson UPDATE service, it indicates the software is up to date. pls help me.
Depending on how old the phone is, your battery may have reached the end of its "useful life". (Batteries generally will decrease in the length of time they hold a charge over time. This will usually be somewhere between 2 and 3 years, but there is no set time period, and it is also dependent on model specifics, usage, etc.) Of course, useful life, if disclosed at all, by most providers / manufacturers is certainly not emphasized, and is in print so small that you could not see it with a microscope.
Or, it could simply be that the battery is defective, particularly if this is a relatively new unit. Based on the description of the problem you have presented, the first step I would take is to replace the battery, and see if the phone will then begin to charge when plugged in. (You could theoretically try this right at the retail store.)
If the battery is not the problem, and/or replacing it does not help, or you need further assistance please post back and we will attempt to work through further steps. This solution is based primarily on my experience with the same exact issue, and the cause was the battery. Once replaced, all was well...
Thank you for using and rating FixYa!
Some time it happens to me but waited for more than 30 min then it is on if not try replacing new one
sofetwere of my cellphone W810i is distroyed and i want new softwear
