Question about Candy CDC266 Dryer
Candy cic 60 keeps tripping electric
My candy cic 60 keeps tripping my electric i have replaced the thermal fuse as it was blowing cold it seemed to work for a while but then it started to trip electric and now is becoming a pain please help
peter
    President:
  • 1,462 Answers
Take cover off fan and see if there is signs of water there. a common cause of tripping is that water is thrown up from the fan onto the element.
get back to me if you find this
Posted on Aug 13, 2008
The dryer is not getting Hot ? blowing cold air
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Here is a video to walk you thru the troubleshooting process.
Jan 26, 2011 | GE DCVH515EFWW Electric Dryer
My dryer still runs but does not heat up (just blows cold air), any idea how to fix? Will it be a thermostat or the heater element itself?
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Jan 04, 2011 | Whirlpool AWZ7303 Electric Dryer
THE DRYER WON'T DRY, ITS COLD
Hello there:
If your dryer will not heat up during it's cycle please try the folowing suggestions
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring
Sep 27, 2010 | Dryers
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
Does not heat I have cleared the vents and filter
if your dryer doesn't heat, check these:----
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 11, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
I have 60 amp circuit breaker on my electrical a/c heater with a 45 amp fuse. I had the unit for 7 years with no problem. This month the 60 amp circuit breaker keeps tripping when the heater goes off. The...
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Dec 07, 2009 | Goodman CKL42AR42 Air Conditioner
My dryer is blowing cold air and not drying at all
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 03, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Candy cic 60 fiter light
faulty exhaust thermostat or heater and thermostat complete, check for continuity should be normally closed (complete circuit)
Jan 06, 2008 | Candy CDC266 Dryer
The Candy CIC 60-1
replace the element
Dec 30, 2007 | Candy CDC266 Dryer
Dryer stopped drying.
Electric dryers are equipped with a thermal fuse or thermal cut-out. They are usually located near the heating element next to the thermostat, and typically blow when there is an overheat condition (usually caused by poor air flow attributed to clogged ducting and/or lint build-up in the dryer). The thermal fuse (or cut-out) is a one-shot type of fuse. Once it blows it is non-resettable and must be replaced. In some model dryers when the fuse trips it will only disable the heating element and the dryer drum will still rotate. However, in some dryers when the fuse trips it will also disable the drive motor. I hope this helps.
May 12, 2007 | GE Profile Harmony DPGT750EC Electric...
Candy CDC266 Dryer Logo
368 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
