Question about Microsoft Xbox 360 Console
Two flashing red lights on left side of console
  • 3 more comments
  • cozmokramer Sep 16, 2008
    cant reset it 2 red lights on left side tried to let cool down didnt
    work
  • luigibean Nov 19, 2008
    Its the same with me too.... Its really annoying though, does it mean its overheating?
  • trout1521 Nov 22, 2008
    My xbox 360 starts up but after 5 minutes or so the 2 left quardrants of the circle flash red. Overheating?
  • thadius1 Jan 01, 2009
    one flashing red light on lower right side... dvd door will not open?
  • tsmith1954 Jan 02, 2009
    The moment i switch on the Xbox, wait couple of seconds then 2 red lights on the left starts to flash. have tried reset but noy joy.
    Help please
Cant reset. unplugged still messed up
Posted on Sep 16, 2008
When i looked on the xbox website i read that thats an overheating issue... internal problem mine had that problem and luckily i had the isurance that i payed extra when i purchased it. if i were u i'd like into it. hopefully this was helpful information
2 red lights start flashing
Two red lights flashing on the Xbox 360 means that the system is encountering overheating issues. What you can do is to let your console cooldown for about half an hour and you are ready to go. Also, if you are connected to a Hi-definition output and running on 1080p, you might want to downscale it to 720p as the console generates less heat in lower resolution. Hope this helps..
May 12, 2010 | Microsoft Xbox 360 Console
overheated. let it cool of, clean it and place it somewhere cooler.
Mar 20, 2010 | Microsoft Xbox 360 Console
Two red lights left side flashing on the xbox consol do you what what the solution is?
hello,
Two red lights lighting up means that your 360 is overheating... try to move your 360 to a cooler spot. you can also try to vent the heat by pointing a desk fan directly to the console.
I hope this helps.
- HotRatchet
Feb 11, 2010 | Microsoft Xbox 360 Console
XBOX 360 TWO RED LIGHTS FLASH
the two flashing lights is the code for your console overheating make sure nothing is on top of or behind the xbox and make sure it is not in an enclosed space
Sep 20, 2009 | Microsoft Xbox 360 Console
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
Red lights flashing
You overheated call microsoft and tell them you have 3 red lights instead of 2 they charge 150$ for 2 lights but its free for 3 and its the same issue.
Mar 20, 2009 | Microsoft Xbox 360 Elite Console
2 red lights flash on left side
I suggest you to try DIY Guide that wil explain solving the 2 flashing red lights along with some other common problems of Xbox like Disc Read Error, No Video Problem and most famous RROD. Even a novice can solve the problem with the help of step by step process given at the guide. I think it's worth trying. If you try this method, you won't have to wait for 3-4 weeks and you can enjoy your gaming experience within 2 hours, once you try this guide.......
Jan 10, 2009 | Microsoft Xbox 360 Console
What does 2 flashing lights mean on an xbox 360?
The two red flashing lights on the left side of the circle indicate the thermal limit has been reached. (over-heating) Check to see if the fan on the back of the unit is blowing air. There are external fans that can be added to keep the GPU. (Graphics Processing Unit) and CPU (Central Processing Unit) temp down. Keeping the temp down can prevent the dreaded RRD. (Red Ring of Death) Here is link as an example of a cooling fan. http://www.gamerepairparts.com/xbox-360-cooling-.html
Shop around and find one that you like. Remember, when it comes to these computer chips, cooler is safer.
Dec 31, 2008 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
250 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
