Question about JVC Audio Players & Recorders
No power system dead jvc cas 300 audio system
  • 1 more comment
  • needoo 6 Aug 13, 2008
    there is some power. fuses ok there is no diplay
    when pressing on off switch, the on off switch on
    front of unit does not light up the unit is dead
    it appears the 7.5 + line and the 4.7 + line is
    missing from the regulator board
  • needoo 6 Aug 14, 2008
    i will get it checked, thanks
    Genius:
  • 2,035 Answers
First get it check if it works in a local service center , there possibles of bad power supply wiring the car .....,then is player is defective get it serviced ...
Good luck..
Posted on Aug 13, 2008
  • 4,234 Answers
There are two possibilities here.
1) The standby power supply has failed.
2) There is a problem in the final amplifier stage that is causing the unit to enter protect mode.
Check the small transformer inside for continuity. The primary side should read low resistance when using an ohmmeter. If it reads infinity, the primary winding is open and the transformer needs to be replaced. This often occurs during a power outage. A short power surge opens up the primary side. Without the standby voltage, the internal CPU won't be active to receive the power-on command.
If the unit attempts to start and shuts down, there probably are shorted transistors in the final output stage of the unit.
In either case, without seeing the unit and takeing a few measurements, remote diagnosis is near impossible. I would suggest that you get a detailed repair estimate from a service shop and post the results here. We should be able to guide ytou through the actual repair. This estimate should not cost more than $50.
Keep us posted.
Dan
  • ABRsvcs Aug 13, 2008
    I would have expected +5V and +12 not +7.5. Check any ICs that hang off of the 12V line for a shorted condition. Also check the regulator. It may be a 7812.
    Keep us posted.
    Dan
    Master:
  • 521 Answers
Try to dry the circuit board with the dryer ,so as to remove any moisture on the board which would be shorting the tracks.this normally solves the problem if it was working properly before.
    Guru:
  • 1,894 Answers
Have the unit opened and check for the blow out fuses..
  • dewan nafees ahmed Aug 13, 2008
    also try a different power supply and use a surge protector for the unit..
    replace the existing fuse with a new fuse.
    keep us informed about the results..
    thank you
    good luck
How would I factor using a TI-86?
its round has lots of squares and has a handle
Sep 11, 2013 | Texas Instruments TI-86 Calculator
How to factor
The TI 86 calculator does not manipulate algebraic expressions. If does not have a Computer Algebra System or CAS. Try the TI 89 Titanium, TI92/92PLUS, Voyage 200 PLT, TI Nspire CAS, TI Nspire CX CAS. In Casios you have the ClassPad series (300, 300Plus, 330 Plus and the latest 400. The ClassPad 400 has a color screen. It is also orientable portrait or landscape. Other Casios are the Algebra FX 2 and 2, and the FX 9860 G Plus/ SD. In HP you have HP 50G, HP49C, HP49G+.
How to set up CAS
I am sorry to say, but there is nothing for you to set up. Anu calculator comes with a CAS or does not come with a CAS, and this one does not.
If you want a calculator with a CAS, here is a list of some of them
Casio FX-Algebra 2.0
Casio ClassPad 300/300 Plus/330/330 Plus
HP 50G/49G+/40G39G+
Texas Instruments TINspire CAS
TI Nspire CX CAS
TI Voyage 200PLT
TI 89 Titanium
TI 92 Plus
Jul 09, 2012 | Casio FX991ES Scientific Calculator
UX-C30C
If competely dead, open fuse or the power transformer has a built in thermal fuse that opens, replacement only way.
Mar 17, 2012 | JVC UX-C30 Shelf System
Does casio Fx-115ES has a CAS system?
Sorry. It does not have a CAS. Casio Calculators with a CAS are the FX-9860G (and similar models) , FX Algebra, ClassPad 300/300PLUS//330.
Mar 07, 2011 | Casio FX-115ES Scientific Calculator
Need to get face for jvc KD R-300 where can I get one.
Ebay is your best bet....Be sure to look for a power seller with good feedback.
Nov 14, 2010 | JVC AM FM CD DET FACE CAR STEREO
How do i calculate limits on my Casio fx-115es? Ex. lim x->3 for (x2'-0)/x-3
Sorry, but you cannot calculate limits of functions with this calculator. It does not have a Computer `Algebra System (CAS). For that you need a graphing calculator with CAS: Casio ClassPad 300, 300PLUS, 330, HP 48 GII, HP49 G/ G+, HP 50G, TI-NSPIRE CAS, TI89 Titanium, TI 92/92PLUS, TI Voyage 200 PLT. It is still a very good scientific (non graphing) calculator
However, you can calculate numerical derivatives, and numerical integrals, solve linear and non-linear equations.
Even though this post does meet your expectations, do not let that prevent you from rating it.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Color code for speaker out on a JVC KS R140 car casette player
White - left front
Grey - right front
Green - left rear
Purple - right rear
Yellow - memory power
Blue - remote power (power ant, amp or eq power)
Mar 20, 2009 | JVC KS-F150 Cassette Player
I am missing some parts
Jvc home theatre system cable that connects the the bub and the dvd
Jul 04, 2008 | JVC TH-M606 System
Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Jan 27, 2008 | JVC RX-1028V Receiver
129 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
