Question about Marantz Audio Players & Recorders
My CD player comes up with the message "DEF" when switched on and does not play. The tuner and tapes have no problem. can you please help The model number of my Maramtz unit is "MX520 My contact email is cludan@hotmail.com thanks joe
  • 2,071 Answers
If not locked by a region code,then it needs to clean the lens..
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 13, 2008
I have an Akai stereo system Sound processor EA750 Tuner pre amp TP750 CD player CD750 Amplifier PH950 Cassette Player HX950 When I switch on a notice appears "Error" I cannot find...
Since you have so many items in your music system, it is the correct connection that matters. Any wrong connection (sequence wise) will give errors. So, follow the instructions that came with each one of them.
Dec 06, 2010 | Audio Players & Recorders
Service manual for realistic STA-2080
I have a sta-2080 realistic receiver and wide range frequency equalizer plus a tape deck sct-22 all realistic.My problem is when i play the tuner or cd player witch is connected to the aux
the volume goes soft and then loud with a lot of cracking sound now ther is hardly any volume.when i play the tape deck it has it own volume control every thing is good so what parts do i need. thanks corneil
Nov 22, 2010 | Audio Players & Recorders
Hello, I have found a Sansui DA-T550 music-system with AM/FM stereo tuner, integrated amplifier, cassette deck and turnable/gramophone (placed separated). It seems like the system is working OK. My...
Hi!
I have the same deck. Did it come with rammophone or are you using your own grammophone?
I have it with original grammophone and I don't need a remote control, I don't even have it. You just turn on your grammophone and it is automatic, just place the needle on record and it should switch and play automatically. That is if you have connected the wires right (two wires for sound, one for automation, all in the same area).
If you have separate grammophone, I am assuming you just need to place two wires into the separate phono channels and it should work. There is just no automatic detection, so you have to swithc to mono manually: There is a button on the right, beside Volume control "tape to CD" or something.
To play the tape, just simply push the play button on the bottom, should work, or you could try tape to cd button off and see if it detects automatically when tape is inserted.
Currently I have it taken apart and there is tape detection system apparent. Its quite automated reciever, which sucks, because all kinds of problems appear and it is difficult to fix.
On my Sansui, the tape player starts winding slowly when pressed play button. And the tape motor seems to be on always, even when the tape is not used, and the motor is really loud. --Need to find a solution to this problem. And I hate it switch to radio/FM every time the record stops. Plus the original grammophone doesn't work correctly, it is supposed to take off the needle when record reaches an end, but it just pushes the neelde to the holder... over the record..... "screeeeech".
Nov 15, 2010 | Audio Players & Recorders
Have a VR-407 receiver, all of a sudden there's no audio coming out of the speakers from the TV. Also, DVD, tuner and CD player have no sounds. Speakers are only a couple years old.
Check for basic things like speakers being turned off or switched to speaker b from a and the tape monitor switch being on. Larry's Electronics.
Apr 27, 2010 | Kenwood VR-407 Receiver
When I play CD only the right speaker is play but
first- is the tuner set to mono or stereo? if stereo, stop using the analog rca jacks and use an optical (toslink) cable to transfer your audio to your receiver. almost all cd players have this output and the same with the receiver. better still, if you are using a late model cd or bluray, and your receiver has hdmi inputs use those as they will transfer both audio and video with one cable.
Oct 29, 2009 | Sony STR-DE575 Receiver
I have just been given a Hitachi ax-m68 amplifier.. can it only be used with the other seperates it comes with such as the cd and tuner, or can i use it for decks and a mixer somehow? I dont have the cd...
to use it with either decks or a mixer check to see if it has record out and play in ("REC OUT"/"PLAY IN") for tape 1 or tape 2 if so you can use a mixer connected there. If no tape inputs or record out you could only use the CD ("tuner" is a internal selection not an input selection) as play back connections.
Post back if you have more questions
Oct 28, 2009 | Onkyo TX-SR703 Receiver
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
101 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
