Question about Nintendo Super NES Console
Game color all of the sudden the color of my snes games carries a pink hue the opening screen looks fine but when i start to play the color is all off help please
  • gl_au88 Oct 27, 2008
    mine does that too?
    any ideas?
    Problem Solver:
  • 9 Answers
The pinned connector in the console is dirty, as are the contacts on the games. Pins or tabs are made of brass, which corrodes over time. liberal cleaning is necessary to get them in good shape again. Rubbing alcohol and a q tip works pretty well at cleaning them. Dip one end of a q tip into the alcohol, and rub away on the contacts on the game cartridge. You'll see quite a bit of black crud develop on the q tip. Then, wipe it down with dry end. Grab another q tip and repeat. Then do it again. However many times are necessary for the tabs to be shiny, and the q tips to come up clean. THEN you take a dry q tip and do your best to polish up the tabs with it, rubbing in an up and down motion. You'll find that even more crud comes off after a rigorous polishing. As for the pinned connector in the console, you'll need a clean toothbrush dipped in alcohol, and scrub the daylights out of it! Its going to be really hard to judge whether or not the connector in the console is clean, so you may want to get a flashlight and a magnifying glass to inspect the tabs. Take a business card and fold it in half (paper works to if folded three times) and while the connector is still wet with alcohol, insert it in between the connectors and try to get the excess alcohol out while gently rubbing the pins. pieces of paper can get caught in there, so beware, you'll probably have to blow the lil pieces out, or let your toothbrush dry, and use that to get them out. This is a very tedious task. If the problem persists, you'll need to get an snes screwdriver and new connector (all over ebay), and just replace the connector. Be sure to clean your games regularly, AND ONLY USE ALCOHOL and cotton tipped q tips. Anything else will remove too much of the brass tabs, and you will ruin your games
**while I don't recommend this, it is possible to take a very fine grain sandpaper, say 1500-2000grit, and use that to sand the connector in the console, It will remove material, but will make it work again in most cases. But be warned, once it gets dirty again after such a procedure, the connector will need to be replaced, as it will most likely be damaged beyond repair**
Posted on Oct 29, 2008
Snes doesn't read games
Well it sounds like the console it's self needs to be cleaned out then 4.5 mm bit screw driver to open her up lukue games sell those 4.5 mm game bit tool compressed air to clean it out and it should work
Sep 29, 2012 | Nintendo Super NES Console
Hi I recently purchased a snes, it was working fine but the power cable was a bit dodgy, but when placed in a certain position works fine, it still seems to work and gives power to the console. The problem...
It is possible that you will need new cords. (It sounds like you power cord has a short in the cable somewhere, so it may need replaced too.) A new video cable may fix the problem, but if it doesn't, the SNES may be on its las legs. In that case, you will need to purchase a new SNES or just turn up the brightness on the TV.
May 01, 2011 | Video Game Consoles & Games
M still getting a rainbow effect on my SNES, its extremely noticeable when the screen goes black or is a dark scene, when the colors go down the screen i get green bushes turning blue, blue water turning...
Well I think that there might be an connection problem with inside of the console like the 62 pinconnecter has gone bad or one of the chips is broken you should buy a new one if its that awful.
Dec 16, 2010 | Nintendo Super NES Console
XBOX Live plays back with pink hue
*YOU DO NOT NEED TO SWITCH TO STANDARD DEFINITION*
To view the videos via HDMI, you need to switch the HDMI Color Space setting to "RGB". To do this go through:
My Xbox > System Settings > Console Settings > Display > HDMI Color Space > and from there select RGB
I had this same issue when watching movies from a USB flash drive and this worked perfect, so I hope this helps those of you who love your HDMI as much as I do.
Aug 17, 2009 | Microsoft Xbox 360 Console
Two Player Game Mortal Kombat SNES
start a 1 player game then when screen loads press start on pad 2 it should take you back to the caracter selection screen
Jun 03, 2009 | Video Game Consoles & Games
Dead RF-out on SNES and vertical lines on Multi-out
The problem is likely in the IC soldered to your SNES circuitboard. The cheapest way to solve your problem is to replace the whole SNES circuitboard. These boards run about 20 dollars, Google part SNSPT007 or SNSPT009, depending upon if you have the older or newer version SNES. There is no soldering involved, so it should be an easy fix if you can open your SNES.
Apr 19, 2009 | Nintendo Super NES Console
Top screen of DS has pink hue.
this is happening to me right now and i just say call nintendo dog
Oct 25, 2008 | Nintendo DS Console
Xbox 360 graphics
Its likely u just have the sockets for ur av cable plugged in incorrectly, this happened to me, the screen was pink though, i fixed it soon enough
Dec 01, 2007 | Microsoft Xbox 360 Console
Nintendo Super NES Console Logo
120 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
