Question about Sony RDR-GX300 DVD Recorder
CANT FIGURE OUT HOW TO RECORD OFF AN 'AV' SETTING
HI THERE I HAVE A 'SONY RDR-HX780' DVD RECORDER/PLAYER AND I HAVE FIGURED OUT HOW TO RECORD TV CHANNELS BUT I CANT SEEM TO FIND HOW TO RECORD OFF MY AV1 OR AV2 CHANNELS ,WHICH IS WHAT WE USE FOR SKY/CABLE TV. CAN YOU HELP?
THANKS
MATT
  • ishakpasa Nov 16, 2008
    hi there, connecting satellite receiver to sony rdr-hx780 dvd recorder , I am unable to change channels with the recorder and therefore can not record different programs from different stations:(
  • samatthews Jan 19, 2009
    Hi. I'm having the same problem. My TV channels works great and I can record from them. However, I have the Grundig Free4Sat digital box, which is fantastic, but I can't seem to record from it. If I'm in the AV1 or AV2 mode watching the channels and select to record the satellite channel I'm watching, then press the button to select, it over rides and goes back to the TV channels. I can't seem to record from the satellite channels either. I'm also using the Sony Bravia television that was made for the Sony HX780 DVD Recorder.
    Genius:
  • 1,027 Answers
The method is the same as for TV channels; select the input (i.e. view the desired channel), then press the record button. AV1 and AV2 usually are at the end of the channel list, and can be found by pressing the channel UP or DOWN buttons.
Posted on Sep 03, 2008
SOURCE:
Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
May 08, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
I cant get new RDR-HXD990 DVD recorder to record to the harddrive
We sought assistance from someone in the neighbourhood and they were able to assist us with easier instructions than the long winded directions in the manual.
Apr 18, 2009 | Sony RDR-HX510S DVD Recorder/HDD Recorder
Remote control for Sony DVD recorder RDR GX3
I just replied your question about remote.
Please click HERE to see.
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
Sony rdr-hxd870 - how to record onto hard drive?
JUst press Record either on the remote control or on the main unit!
Seriously, how retarded can you get!!
Jul 22, 2008 | Televison & Video
Sony rdr hx510
i think its your tv. Have you got a widescreen tv?  when i changed my old tv for an lcd the problem disapeared
May 07, 2008 | Sony RDR-HX510S DVD Recorder/HDD Recorder
Sony RDR-GX300 DVD Recorder Logo
325 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
