Question about Saeco Magic De Luxe Espresso Machine
Excessive water collected in the tray when making coffee
History:Have the machine approx, 5 years, 1 year ago the motor was replaced. I Descale the machine once per month. It seems there is a problem with the water flow of the machine. and during grinding of the coffee the machine is very noisy. The last descaling there was already this noise and after the descaling we had the problem with water. In addition since the motor was replaced the the heating shelf is now constantly boiling hot and the replace the button cap with other ones so there is now no option to turn this off. Help we have spent around 500eur on it so far and i would like to have a problem free machine.
  • babamarkos Aug 19, 2008
    Thankyou.so what happened was that after the descaling meant i needed to adjust the grind of the coffee..and it seems to have done the job.Gave it a good wash the other day.
  • 515 Answers
It can be the flow meter that needs to be replaced.
Make sure the filter in brewing unit is clean.
Hope this will help you.
/Mirran
Posted on Aug 13, 2008
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Error code 5 on saeco minuto coffee machine
Error code 5 means the water flow is obstructed. Here are possible locations:
1- The machine was not descaled. Calcium deposits are clogging the water system.
2- The flow meter is not passing impulses for water flow speed & quantity.
3- Descale Descale Descale.
Before you select the automatic descaling, make a few espresso without adding coffee grounds. The automatic cycle does not clean the coffee side of the machine. You have to do it intentionally.
Dec 18, 2016 | Saeco Coffee Makers & Espresso Machines
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Can you descale a coffee machine with white vinegor ?
Yes. A 20% solution of white vinegar will descale any coffee maker. I prefer to run straight water for 1 cycle after this process to ensure no vinegar aftertaste remain. I've been using white vinegar to descale my coffee makers for years and it works great.
Aug 09, 2011 | Philips Senseo HD-7810 Coffee Maker
My machine was less than a year old when the cup sizes I choose didn't match the size chosen any longer. Now it shuts off after every cup brewed. I do DES ale every six monist or less actually and am try...
Your machine has a 1 year warrenty, call the company, 1-866-901-2739. They will send you a new one. Make sure you have the serial number before you call, pull out the drip tray, and look on the machine.
Mar 04, 2011 | Keurig B70 Coffee Maker
What does it mean if the deescalation light comes on after approx 1 year of use?
descale the machine.
get some distilled white vinegar and run it through the machine. Detailed instructions on how to do this are in your instruction manual.
Apr 04, 2010 | Keurig Elite B40 Coffee Maker
Leak
if you clean your brew unit and coffee lines infrequently you're coffee may taste differently when you do get around to cleaning them.
If you are not happy with the taste, I would receommend the following steps
1. A Good Descale (See our article here for on Descaling your Coffee Machine for details) - This will remove excess mineral build up.
2. Try a Saeco Cleaning Tablet in your brew unit - this will remove excess organic build up (Coffee and Grease)
3. Use only filtered water
4. Rinse your brew unit every time you empty your coffee dreg drawer
That should bring your machine back to optimal coffee making condition. If you are still not happy, try some different coffee blends for a while - a change can be as good as a holiday
Paul from Coffee Shrine
Saeco Coffee Machine
Aug 20, 2008 | Saeco Magic De Luxe Espresso Machine
Keurig B40
If the machine is new, call keurig.. There telephone number is on the web site. They are warrented for 1 year.
Aug 16, 2008 | Keurig Elite B40 Coffee Maker
After descaling, it still says descale how do I reset it?
Please contact the service center and speak to Steve at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700 Steve
info@electra-craft.com
www.electra-craft.com
Aug 01, 2008 | Espressione Caf? Dolce Aroma
Saeco Magic De Luxe Espresso Machine Logo
74 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
