Question about HP Officejet 6310 All-In-One InkJet Printer
Pwer Reset Im Having prblems with my Officejet 6310 keeps going tp power reset, i restatrt but nothing happens, can you help Kevin Newbury
  • 5 more comments
  • SSNs4ever Aug 23, 2008
    My Officejet 6310xi All-in-one keeps going to power reset also. I went to hp.com and followed the recommended troubleshooting steps there. I also used the directions to reset the printer to factory settings and did the steps for power supply problems...no joy...
  • tesoroyoro Aug 23, 2008
    My officejet 6310xi printer keeps flashing and tells me to reset power. I turn it iff and on unplugg rebot but it keeps telling me the same
  • mack69 Nov 25, 2008
    My Officejet 6310xi All-in-one keeps going to power reset. I went to hp.com and followed the recommended troubleshooting steps there. I also used the directions to reset the printer to factory settings and did the steps for power supply problems.
  • Anonymous Nov 27, 2008
    As with the others my printer stopped working and all sorts of lights began flashing and the screen said reset power. I've taken the same steps as the other people with no luck. Any help would be appreciated.
  • martinez2196 Nov 30, 2008
    how can i reset my printer, the printer is flashin on and off and i cant seem to do anything
  • rhuson Nov 30, 2008
    HP 6310 keep flashing lights in multiple areas and asking to Reset Power. Have done this a few times along with rebooting and still does not correct.
    Any earlier solutions to this same problems that others have encountered?
    Thanks,
  • blackwelllar Apr 29, 2009
    Power reset on HP Officejet 6301xi All-in-one produces flashing lights and all attempts to correct, including plugging into wall outlet and following "setup" commands recommended by HP cust service were unsuccessful.
My HP 6310xi printer reset power screen keeps flashing. How do i reset it
Posted on Aug 23, 2008
Buy a Brother
Posted on Sep 16, 2008
Hola tengo la resuesta el problema es el cabezal donde ban los cartuchos no son configuraciones noson los motores no es latargeta logica solo canbien el cabezal con todo y cable plano y gual i no nesesitancambiar todo el caritio donde ba el cabezal buno solo cambien el cabezal eso me funsiono suerte espero qe les ssirva
Posted on Aug 26, 2008
HP 6310 Officejet All-in-one RESET POWER
How old is it, you might just need to get a new power cord
Apr 20, 2012 | HP OfficeJet 6310 All-in-One Printer...
HP Officejet 6318 displays "reset
Go to this LINK.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | HP OfficeJet 6310 All-in-One Printer...
Officejet 6310 won't turn on.
Ok try unplugging the printer for about 15 minutes and plug it back in that will reset the printer and it should work fine.
Let me know how it works out
Dec 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Master Reset
I don't have a 6310 but I do have 4 printers one of which is a 5610. I never bothered w/ a reset switch because I would just turn the printer off, then unplug everying for 2min. Then I would reconnect everything back. If it doesn't work, I suggest you uninstall the software and reinstall it again. Let me know if this helps.
Nov 10, 2008 | HP Officejet 6310 All-In-One InkJet...
My Officejet 6310xi All-in-one keeps going to power reset also. I went to hp.com and followed the recommended troubleshooting steps there. I also used the directions to reset the printer to factory...
Hi. I just got off of the phone with an HP case manager. I was ready for a refund, but he helped me and now my printer is working fine. The key is to have your Officejet 6310 plugged directly into a wall socket. The variations of power through a surge protector often cause a power shortage to the unit. The 6310 needs the 110 volts to operate. Surge protectors will sometimes rob the unit of this power. Follow these steps:
1. Unplug the power cable & ethernet/usb cable from the unit (stand alone mode). Let it sit for a minute.
2. Plug the power cable directly into a wall socket. Then plug the power cable into the 6310.
3. After it powers up, push the "Setup" button.
4. Right arrow to "2.Print Report."
5. Press "OK" button.
6. Right arrow to "4.Self-Test Report."
7. Press "OK" button.
A page should print showing alignment and color settings. Now you're back in business!
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
HP deskjet 6310 won't stay on.
hi dear
try this
> unplug the power chord while the printer is turned on
> press and hold the # and 3 button on the printer at the same time.
> while holding it, plug the power chord. wait for 5 seconds and release your hands.
> once the reset is finished, check whether you are having the same problem.
thanks
Mar 23, 2008 | HP OfficeJet 6310 All-in-One Printer...
Hp officejet 6310 AiO reset steps
Two other resets are available.
#6 is a partial reset
#9 is a full reset
Jan 01, 2008 | HP Officejet 6310 All-In-One InkJet...
My printer keeps requireing a power reset
hi,
try to perform a semi-full reset
thanks and regards
agnel
Mar 15, 2007 | HP OfficeJet 6310 All-in-One Printer...
HP Officejet 6310 All-In-One InkJet Printer Logo
2,027 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
