Question about Bosch Microwave Ovens
Change bulb in HMG 85 - Bosch Microwave Ovens
  • Bosch Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 18, 2008
How to change the bulb for kleenmaid wall oven model T055x
Changing the bulb
Warning: disconnect the appliance from the power supply before replacing the bulb
- Turn the cover one quarter turn to the left.
- Unscrew the bulb and replace it with a heat-resistant (300 °C) bulb of the same size with an E14 base - 15 W.
Aug 12, 2017 | Microwave Ovens
I need a manual for the Bosch hmg 2210
don't know what a bosch hmg 2210 is. I don't own one. What is your problem with it?
why not just check online. might be easier than expecting us to find it for you.
Aug 19, 2014 | Microwave Ovens
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
Bosch combination oven/microwave HMG 8220GB start button doesn't work
This is a door switch problem, one of the door switches has malfunctioned preventing the microwave oven from running.
May 14, 2012 | Bosch Microwave Ovens
Work out how long my battery will last using a
Your said your battery is rated for 85 amps / hour. This means 1 hour at 85 amps, 42 hours at 2 amps, 85 hours at 1 amp or any number of hours in between determined by 85 divided by the number of amps of the load connected. The microwave uses 600 watts. Since we can't reliably determine amps in an AC circuit - I can get close using the DC calculation. I'll assume 120 Volts at 600 watts for the microwave. Watts = Volts multiplied by Amps, so the microwave uses about 5 amps (120 x 5 = 600). HOWEVER, this is not an accurate way to determine AC amps when voltage and watts are known. I'll bet the microwave has the actual amount of amps (along with the model, voltage, wattage etc.) on a label on the back, side or inside the door. This is the information that is accurate. Use the amp rating provided on the name plate to determine how long the batter will last. Assume 8.5 amps is the value provided on the name plate.. 85 amp hour (85 AH) battery would supply an 8.5 amp (8.5 A) load for 10 hours because: 85 AH divided by 8.5 A = 10 H. The quality of the battery, and the losses contributed by the inverter will reduce the actual amount of time that the battery could supply the microwave.
I hope this helps!
Sep 18, 2009 | Panasonic Microwave Ovens
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
Purchased Carrefour Microwave Oven in the sale - NO INSTRUCTIONS
Here you go
http://www.fixya.com/search/p126535-ge_jvm1650_1000_watts_microwave_oven/ge_jvm1650_service_manual
Please leave feedback
Thanks
Feb 11, 2009 | GE JVM1650 1000 Watts Microwave Oven
Fan and Lights do not work
Sorry a bad controller printed circuit board or what GE calls a smart board. I have seen these smart boards as low as 85 bucks, go up to a price of 179.00!
Sep 18, 2006 | GE JVM1651 Microwave Oven
Microwave Ovens Logo
621 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
