Since installing the latest version of messenger whenever i turn my pc on a message comes up on my computer saying the following. Photo gallery The feature that you are trying to use in on a network resource that is unavailabe. Another box comes up saying that an installation package for the product photogallery cannot be found. I can only get rid of the box by ending task in task manager. Untill i do that everything else on my pc runs really slowly. I think photo gallery may not have installed properly the first time so i've tried uninstalling & reinstalling windows & photogallery but no change.
  • 2 more comments
  • Michelle Latimer
    Michelle Latimer Aug 13, 2008
    Sorry i've just seen my last msg & bad typing. Thank you for the promp reply, Just to add i have tried completely uninstalling messenger & reintalling it the first time i did this i did so with out adding the photogallery programme (no change though) & the second time i did it i added the photogallery to see if this helped but it didn't. Even after i completely uninstalled messenger when i turned my pc on i still had the same problem. The annoying thing is I can't do anything on my pc untill the msg box has come up & i've ended task which takes about 5 or 10 min's every time i turn pc on.
  • Michelle Latimer
    Messenger was working ok but I keep getting signed out all the time however i think this may be due to general connection problems as my internet has been playing up as well. I tried clicking start & run & typing msconfig into the little box & cliking on ok which takes me to system configuration utility but i'm not sure where to go from here. I can't see where the auto run tab is? Sorry to be a pain, any ideas?
  • Michelle Latimer
    Ok i can see exactly what you're saying now. I've had a go so will restart & see what happens. I didn't see anything directly to do with photogallery though so it may not wrk, definately worth a try though :)
  • Michelle Latimer
    Thank you. That seems to of done the trick. I can finally turn on my pc & start using straight away with out all the messsing about. Everything seems to be working fine. Thanks again :)
  • 477 Answers
Hi
Try to uninstall the new messenger and then reinstall it. and if you don´t whant the photogallery installed you can uncheck it in the begining of the messenger installation. If you want it installed you can install it after the Messenger installation is done and working.
Posted on Aug 13, 2008
  • Filip Eastman Aug 13, 2008
    hi again you can try this.
    you can stop the msg to popup.
    click start -> run and write msconfig
    click on the autorun tab and unmark everything that is named msn or photogallery and so on. then the popup should stop. restart and try to run messenger after that. does the msn work properly then ?
    hi
    I mixed the language is there any "startup" tab there ? when you click on that you will see a list with startup programs that starts when windows starts. unmark all that have something with msn/messenger or photogallery. then ok and restart and if you unmarked the right box the msg should go away. this does not solv the real problem but you dont need to wait on that popup to appear.youre not a pain im just here to help :)
SOURCE:
When downloading yahoo messenger, why do I get an error that says Yahoo did not finish installing because there is a missing component?it says d3d9.dll was not found
Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the d3d9.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
Dec 03, 2011 | Yahoo Messenger
Yahoo Messenger pyavore.search NULL error.
please download a older version of yahoo messenger and try it.
this may sometime clear the problem
Oct 23, 2008 | Yahoo Messenger
Ym stops as soon as I dial the number. Message says : ym has stopped working and will close. 8.1.0.421, windows 7
you are using old version of yahoo messenger..
you need to uninstall the version from add and remove program and install latest version 10
you can download the latest version from http://messenger.yahoo.com
Apr 16, 2011 | Yahoo Messenger
As soon as it comes up, a message comes on saying Yahoo messenger is not working propery, windows will close the program
When problem like this occurs, this means that one or more system files on your currently installed Yahoo! Messenger is corrupted. Just uninstall your yahoo messenger and download and install the latest version at http://messenger.yahoo.com and this should fix your problem. Uninstalling will not delete your contact list so you dont have to worry.
Please let me know if this helps. Thank you for using FixYa.
Nov 10, 2010 | Yahoo Messenger
I want to share photos with here but when begin to share her screen is black where normally the photo sharing takes place needless to say we can share receive or send photos wat is the problem? she...
As much as possible both of you must use the same version of Yahoo messenger for effective photo sharing
Let her install the latest version of Adobe Flash player. This will help in loading image, animation and graphics related.
Click and download this file Adobe Flash Player 10
And send it to her YM. Tell her to install it.
After that, try photo sharing again.
Let me know if she is happy with that.
Thank you for using Fixya.
Jun 09, 2010 | Yahoo Messenger
I have a yahoo messenger profile picture i would like to use on fixya how do i get it transfered over to fixya
If the photo is on your Yahoo Messenger photo gallery look for it here :-
Start > Computer > >> Local disk (C) >> Program files >> Yahoo >> Messenger >> Profiles >> Username >> My icons
Right click on photo and 'Copy'
Dec 10, 2009 | Yahoo Messenger
Photo Gallery Can't Open Picture
Goto Your Official laptop site ,Download latest drivers for photo gallery ,install and restart ....I hope this helps you
harish
Feb 19, 2009 | Computers & Internet
Having problem with my notebook pc
If you have Norton Internet Security you need to do the following as suggested by Symantec. If you don't have Norton, let me know, but more or less this is the same across the board for whatever antivirus suite you have, disabled the instant messaging protection and then proceed to download and update the MSN Messenger.
Symantec document ID: 2004110108242406 (11/29/2004)
Disable NAV Instant Messenger scanning to stop the error message.
Uninstall MSN Messenger
Install the latest version of MSN Messenger from MSN.com
Reenable NAV Instant Messenger scanning.
Regards,
Worldvet
Aug 02, 2008 | Compaq Presario 700 470024-192 Notebook
Open Questions:
ROBOSCAN toll free phone +$&{[email protected]*1O69} NuMbEr USA .Anita This ROBOSCAN USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 ROBOSCAN USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the ROBOSCAN USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, ROBOSCAN USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ROBOSCAN USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact ROBOSCAN USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ROBOSCAN USA Calling ROBOSCAN USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ROBOSCAN USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ROBOSCAN USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ROBOSCAN USA's phone numbers against each other. Contacting ROBOSCAN USA in General While I8OO8O31O69 is ROBOSCAN USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ROBOSCAN USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ROBOSCAN USA.Anita
Oct 17, 2019 | Best Computers & Internet
BULLGUARD toll free phone +$&{[email protected]*1O69} NuMbEr USA This BULLGUARD USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 BULLGUARD USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the BULLGUARD USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, BULLGUARD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BULLGUARD USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact BULLGUARD USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BULLGUARD USA Calling BULLGUARD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BULLGUARD USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BULLGUARD USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BULLGUARD USA's phone numbers against each other. Contacting BULLGUARD USA in General While I8OO8O31O69 is BULLGUARD USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BULLGUARD USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BULLGUARD USA.Anita
Computers & Internet Logo
120 people viewed this question
Ekse
Alun Cox
