Question about Yamaha RX-V2090 Receiver
Is there any DTS decorder player that suit with Yamaha RX-V 2090? Thank you.
Try the Technics SH-AC500D Digital Surround Processor. Its outputs should match the inputs on the RX-V2090. I own both units, though I am using a DDP-1 with the Yamaha receiver. I use two separate amps with the Technics to achieve surround sound using my good vintage stereo system (two of them actually - one for front and ane for rear). The Technics is a nice piece of kit.
Posted on Jan 29, 2009
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
I have a Yamaha receiver RX-V665. Whenever the weather is rainy the receiver flashes from Decorder Off to Dolby Digital. We get broken sound and picture. Is this a problem with the receiver? If yes, how...
It sounds a lot like a flaky digital bitstream. What source(s) do that? Of those, which would be affected by weather? I'm assuming the receiver is indoors.
Sep 07, 2011 | Yamaha Audio Players & Recorders
The dts surround sound is not working. No signal detected from the dvd source. Double check on the toslink cable and change to new one but the problem persist.
Your player has as much to do with this as the receiver. It must be set to transmit the DTS bitstream. Even within a given DVD movie there are choices for which of several soundtracks to be used.
Apr 01, 2011 | Yamaha RX-V530 Receiver
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
MY DTS is not working, not sure if connections are done correctly.
You have to use ether optical or coax connection, DVD disk has to have a DTS content (not every disk has DTS)
Dec 02, 2009 | Yamaha RX-V496 Receiver
Cannot get yamaha rx-v663 to play DDTrueHD or DTS HD audio
If your Blu-Ray player has TrueHD or DTS-MA decoding, then it will send a already-decoded audio signal to your receiver. The receiver should then just recognize this as "Straight" decoding, because it isn't actually doing any decoding.
Hope this helps.
Mar 01, 2009 | Yamaha RX-V663 Receiver
Samsung DVD-R155 will not play in Dolby Digital surround sound
You need to buy a digital coax cable Just 1 run out of player and into amp!
Dec 06, 2008 | Samsung DVD-R155
Yamaha rx-v595a problem with dts signal
the unit must be switched to digital in order for the auto function to work, then it will automatically select dts or dolby digital. youn need to check your digital feed from the dvd player.
Dec 28, 2007 | Yamaha RX-V595A Receiver
Yamaha RX-V2090 Receiver Logo
249 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
