Question about HTC P3300 Smartphone
Phone is not working
My phone went dead since past 4 days. Removed the battery, then inserted the battery again. Connected to AC charger for 6 hours. While AC charger was connected no amber light shows. After recharging for 6 hours no green light shows as usual. Once I tried to ' ON ' but got stuck in first white screen which also went " OFF ". Still the phone is dead. Cannot turn "ON" at all. Please help.
  • Jamie DG Aug 15, 2008
    I have same problem.
    Phone dead, no led charging and no switch on.
    Have tried soft-hard reset & bootloader mode, all have no response.
    Have also tried another Batt, still same.
My phone had the same problem and it was a battery charge problem. I bought an external charger and another battery and now everything works fine but I have two batteries and an external charger, the phone doesn't charge the batties.
Posted on Aug 20, 2008
I have a ZTE Majesty and while holding the phone
Pull the battery out and re-insert it. If it still will not turn on, charge it for a few hours and try again. Try turning it on while the charger is connected. The battery might have gone bad. Otherwise take it into where you bought it and see if they can help.
Oct 05, 2014 | Cell Phones
My razor will not turn on, i tried changing the battery but this did not work. what can i do?
There could be a few solutions to this problem.
1. Check the state of your battery, if it has been running out much more quickly (i.e going dead after 1 day), then you might have to change your battery.
2.Try leaving your phone connected to the charger for more than 1 hour, if it does not turn on after that then it must be either: the phone's hardware, charger's problem or the battery.
3. As your phone uses a miniusb connection for charging, maybe try and connect it to your computer to see if the phone comes on, if it does then it must be the ac charger's problem.
4. Borrow the battery of a friend's V3 and if it works then it must be the battery; if it does not work still then the phone's hardware is faulty and you should take it to a repair shop (keeping in mind whether the fee is appropriate for the value of your phone).
Thank you for your question =)
Dec 09, 2010 | Motorola Mobility RAZR V3
The 12 volt battery(LUCAS 065/3) on my FORD FIESTA 1100cc is 4 years old, in that time i have only driven 1,600 miles as my journeys are usually very local. I make sure i use the car twice a week to keep...
Running so few miles has accelerated the aging of the battery - the battery never had a chance to fully recharge in such small trips -  so now you have to replace it a year sooner than usual.
Just replace it.
Aug 28, 2010 | Ford Escort Cars & Trucks
Had phone almost a year, no problems. Couldn't get it to turn off, so removed battery, now won't go on, tried all advise, cept battery out for 6 hours, will leave it out, but have you heard of this? Can...
It could be that moisture got into the battery terminals. Take a Qtip and wipe the battery terminals inside the phone and also on your battery.
Then try installing the battery again and then hook up the AC charger. Try booting up. I had a cell phone once, it was a Nokia and it did something similar. I had plugged the car charger in while I was in the car and I heard a noise like it shorted. I took the phone to trade it in when I purchased a new Nokia and I noticed that the store clerk had taken my phone that would not boot up and hooked it to an AC charger. It powered up. I still purchased the new phone, but try the AC charger and see what happens. If it powers up, it might be the battery. Let the battery charge for about 4 hours, don't keep it charged overnight. Overnight charging will ruin the battery. If the phone still doesn't work, I'd say bring it in and see if you can get it looked at.
Mar 27, 2010 | Nokia 5800 XpressMusic Smartphone
My Iphone 3Gs just went dead.
A lot of these phones get stuck. Reset by using the home and on off buttons. Hold home and on off for 30 seconds then let go of home while connected to computer. Leave connected to computer and restart computer. Leave connected to computer for awhile. Mine came back after about six hours. I think it has something with the RAM and the motherboard powering down. If that doesn't work try putting phone in restore mode and restore.
Feb 03, 2010 | Apple iPhone Smartphone
Was just upgrading the Nokia software on my E65, connected with USB, charged and connected to charger for backup... and the phone just went dead. I've tried everything to get it going again including...
I have the same king of problem for two days now. I can't open my E-65 either. Guess it must be the update that cause this. Now I regret having my phone updated...
Oct 17, 2009 | Cell Phones
HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
May 12, 2009 | HTC Touch HD Smartphone
The phone became dead, recharging led does not light up.
On following the steps as stated in my problem text. I kept the phone idle for 2 hours, then I pressed the "ON" button, the screen lighted up and then went "off" again. I again pressed the "ON" button, the screen lightened up and the windows setup completeded in 2-3 minutes. The phone started to work. I think the phone got hanged since the battry went too low. Now it is working OK. I will always keep the battry charged.
I thank you and all your team mates for all the assistance you have extended in solving my problem. I am grateful that your site gives ample knowledge to sort such problems by the user.
Once again thanks a lot,
Regards
John
Sep 06, 2008 | HTC P3300 Smartphone
Nokia E65 dead during Nokia Software Upgrade
I was just upgrading the Nokia software on my E65, connected with USB, charged and connected to charger for backup... and the phone just went dead. I've tried everything to get it going again including taking the batery out and outting it back in aain, holding the on/off button down for a minute - and nothing is happening. The screen is dead. Is Nokia's new upgrade causing this? I see two other posts to this site with the same problem in the past 24 hours. The upgrade was posted on Nokia.com 24 hours ago. my mail is singh1316@yahoo.co.in
Apr 10, 2008 | Nokia e65 Cellular Phone
HTC P3300 Smartphone Logo
166 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
