Hello...I have a Canon MP160 printer...I have just replaced the ink cartridges due to the fact that the ink indicators came on saying low ink...now that there replaced ..how do I reset the indicators light to go out??
    Sergeant:
    Champion:
  • 214 Answers
Go to printer properties, select maintenance then click the ink reset counter(both color & black)
Posted on Aug 13, 2008
Canon MP160 Printer "Ink Absorber is Full
Canon MP160 PIXMA shows ink cartridge full. How do I empty...as I just refilled with new cartridge, due to stating no ink. Please help..thank you.
Mar 12, 2013 | Canon PIXMA MP160 All-In-One InkJet...
I've changed the ink cartridges in my MP120 twice and the display is still showing that the ink level is low. How do I get the printer to reset to show the correct ink level?
After the refill it indicate your ink level is low.... Don worry about that its nature... it doesn't happen any thing... All the canon printer indicate like that... thanks
Aug 26, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I installed a new black cartridge and now it is not printing. I need the installation guide for allignment
Please follow below instruction. Otherwise, visit this link. Link
We hope we have provided you a solution to your problem.
Thank you.
The Canon Pixma Mp160 is an all-in-one printer, scannermag-glass_10x10.gif and fax machine. Replacing the cartridge in the printer requires little effort. Make sure to use the correct replacement cartridges for your MP160; installing the wrong cartridge type could prevent your printer from working or cause it to fail. Use caution to prevent ink spilling or dripping on you.
Step 1 Identify the cartridge that requires replacement. Press the "Copy" button to display the ink level. "BLK" indicates your black ink cartridge; "COL" indicates your color cartridge. If the display is only one bar (or none), then the cartridge should be replaced.
Step 2 Open the top compartment (scan lid) on your Canon printer. Pull back the compartment support legs to hold it open.
Step 3 Put on gloves, and then push the cartridge down to unlock it. Pull it toward you to remove it from the printer.
Step 4 Remove the tape strip from the replacement ink cartridge. Insert the new ink cartridge (black on the left, color on the right) at an angle, with the gold circuit facing down and towards the front of the printer. Push the cartridge up to lock it in place.
Step 5 Repeat the process if you are replacing multiple cartridges. Close the scan lid when you are finished. If the "Low Ink" warning does not go away, then turn the printer off, wait a few minutes and turn it on again.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Where is ink cartridge keeps saying ink low never changed ink before
With the printer on, lift the lid of the printer. The ink carrier will center on the track. You can remove the cartridge that need replacing, insert the cartridge and close the lid. You should be good to go.
Download and review the instructions from
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Please rate this solution. Thanks.
Oct 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error 4
The error code E4 indicates that ur printer is low on black ink if ur getting this error error code then u need to replace the blak ink cartridge. Hope this solution will solve ur prob
Jul 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Dell 946 new ink still says low ink
You can't. Certain cartridges are not able to indicate a fully charged cartridge after having been refilled. This is due to the fact that they have an ROM chip---Read Only Module--that is not programmable after it has been "used up" by indicating an empty ink reservoir.
Mar 30, 2009 | Dell 946 All-In-One InkJet Printer
How to reset ink cartridge for mp 160
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Sep 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Replaced Original Black Ink Cartridge but still bad low ink prints and low ink indicator lit.
Sounds like the print head is dirty take some rubbing alcohol and qtip and clean the print head.
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Change ink cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
532
Oct 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
143 people viewed this question
jasbo
jasbo
