I recently got an acer laptop and it says it has bluetooth but when i press the bluetooth button it says no device. also when i turn the laptop on it tells me i have to turn the bluetooth on and configure it. i dont know how to do this.
  • 50 Answers
Kindly visit www.support.acer.com and as per product details find the best documents suitable for the issue.
Posted on Aug 13, 2008
SOURCE:
How do i activate bluetooth on my acer 5755 model leptop?
Press the "Bluetooth" button found just above the keyboard. The LED above the button should illuminate.
  • Click "Start," "Control Panel" and "Add a Device." Your Acer scans for other Bluetooth devices in the area.
  • Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
  • If you faced any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at http://www.vtechsquad.com/acer-support/ for troubleshooting.
    Sep 25, 2011 | Acer Aspire 5742Z-4200 Notebook
    How I may use Bluetooth on Acer Aspire 7520G?
    Hi there, please follow the instruction.
    1. turn off Bluetooth button.
    2. run your Acer driver disk & install the Bluetooth
    device. After a while your laptop asking you for turn
    on your Bluetooth. Press the button of Bluetooth. It
    will installing then. After a while another message
    will come in front of you that, Bluetooth device
    installed & ready for you.
    You may also watch the link for some an idea about setup a Bluetooth.
    Thanks & waitimg for your feedback.
    Feb 12, 2010 | Computers & Internet
    Acer Travelmate 5620 bluetooth button won't turn on
    Do you actually see the Bluetooth device in device manager? Normally if it's not turned on it won't appear in device manager. The next thing I can think of is that if the Bluetooth module was not turned on when you loaded the drivers then they won't work.
    And lastly the module may have come lose or unseated from the slot. Are you absolutely 100% sure there's Bluetooth hardware on this laptop? Is this built-in or a USB dongle?
    If built-in have you turned it on? Acer uses a slide switch to turn Bluetooth and Wireless LAN on and off.
    The first thing you probably need to establish is whether the laptop has a Bluetooth module fitted. Plenty of Acer laptops support Bluetooth in some markets and not in others and actually have slider switches to turn Bluetooth on/off but don't have the Bluetooth module fitted.
    Does the unit say that it supports Bluetooth on the sticker attached to the front of the laptop? The models that have Bluetooth typically have this listed on these and will also list it on the packaging that came with the laptop that lists its specs. If it doesn't mention it odds are it's not fitted.
    Acer laptops have the Bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a Bluetooth symbol under the laptop. If you do not see it, there is no Bluetooth. Also, if you press/move the Bluetooth button, and the light doesn't turn blue, there's no Bluetooth module with your laptop (only the button), so your laptop did not come with Bluetooth.
    Also, you can add Bluetooth, but you need to be able to take the laptop apart to a certain extent, such as taking off the cover (top portion), keyboard, and maybe the speakers. The Bluetooth should have a 4pin, 6pin, or 8pin Bluetooth Cable connected to a Bluetooth module. You need to purchase the Bluetooth module, and install it, but you need professional help for that.
    In case your laptop won't have a Bluetooth module fitted. The switch doesn't mean anything, it's present on all Acer laptops whether they have Bluetooth fitted or not.
    You can buy the module as a spare part from Acer and fitting it is easy however buying a cheap USB Bluetooth dongle will be a cheaper option.
    Thank You for contacting Fixya.com
    Feb 02, 2010 | Computers & Internet
    How do you activate the bluetooth
    make sure the driver is installed.
    http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=843&ctx1.att21k=1&CRC=1841181145
    Jan 04, 2010 | Acer Aspire 5536-5224 Notebook
    How to enable bluetooth
    First of all you need to connect bluetooth device to the laptop because most Acer laptops don't usually come with bluetooth device but they have the software/driver that will make bluetooth to work on it. So, I will advice that you get an external bluetooth device connect it to your laptop, the bluetooth application will make the bluetooth device to work. Thanks
    Sep 30, 2009 | Acer Aspire One PC Notebook
    Acer5920
    No there is no bluetooth device inside.
    Acer uses same chassis for other laptops with bluetooth, thats why there is bluetooth button.
    Apr 20, 2009 | Acer Aspire 5920-6727 Notebook
    Bluetooth on aspire 4730Z
    The 4730Z does NOT have bluetooth. Check the specs on it from acer's website. The reason for the buttons are that it share much hardware with the 4930 which does have bluetooth. You will need to add a bluetooth device if you want bluetooth.
    Once again, the a4730 doesn't have bluetooth in it's stock form.
    Jan 26, 2009 | Acer Aspire 5610-4648 Notebook
    I cant get my bluetooth too work acer aspire 1640z with vista
    you may need to download the bluetooth's driver your manufactures support page
    Jan 24, 2009 | Acer Aspire 1640Z Notebook
    Bluetooth Problem
    this will help
    go to device maneger
    check for your bluetooth device
    check if it is activated
    if not activate it
    you could also check for driver details
    just incase you dont know how to go to device maneger
    if your using MSwindows any ver. go to system properties
    Jan 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
    Open Questions:
    Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-] Avast cusTOmER serVIce pHoNe #[+1888^499//5520;-]
    Oct 16, 2019 | Computers & Internet
    [email protected]!~~ {#^l_855^892-OO6O } APPLE Mac technical SuPpOrT NumBer @ wresad +1_855_892_0060 Apple Support '' Apple Support Number Apple is a great platform for unlimited entertainment, only having a membership plan; you can dive deep into the entertainment world. But is this always possible? Not at all, you have to face various issues with this every now and then, but you will be happy to know that Apple Prime Customer Support service is 24*7 active to assist you whenever you experience any sorts of issues with this. Yup! No hassle, no waiting, your every single issue related to Apple will be resolved instantly at a single call to customer support. chat with Apple customer service.USA DAIL Itunes customer Care number our ensured specialists are available constant to offer most sensible courses of action immediately even by methods for our toll free number for Canada and USA.is advancing strong responses for the customers by methods for customer organization as it appreciates the burden and frustration a customer needs to encounter. It is advancing game plans by methods for different sources so the customer can pick the right one according to his tendencies. Itunes technical support. Our submitted gathering of is just a phone way and accessible immediately relentless. Itunes customers can come to us to benefit answers for any of their issues including the ones referenced here under Itunes best without toll number, there are 4 outright ways to deal with associate with them.The accompanying most perfect way to deal with banter with their customer reinforce gathering, according .Ipad Support Avail Ipad Support To Quickly Resolve All Ipad Errors Independent Ipad Support Phone number for Ipad Help The line of tablet computer designed, developed and marketed by Apple Inc. APPLE Customer Service Number +[{1855-892-OO6O*}] to resolve all APPLE products. APPLE is an American multinational company which was founded by Michael APPLE using its company headquarters in Round Rock, United States of America. Contact APPLE for Setup & Installation APPLE Setup Free & Installation APPLE CUSTOMER FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for APPLE Connect, APPLE CUSTOMER Free Phone Number you'll be searching out APPLE Connect setup as well. So, here we're with all cthe setup process and for your to APPLE Connect. Get APPLE Setup Instant Free APPLE CUSTOMER FREE Phone Number Usually, the setup CUSTOMER nique takes a number of time. One CUSTOMER nique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't CUSTOMER-savvy. Let us undergo the method of APPLE Connect setup for Windows and for Mac. So, right here we go hayabanApple is a great platform for unlimited entertainment, only having a membership plan; you can dive deep into the entertainment world. But is this always possible? Not at all, you have to face various issues with this every now and then, but you will be happy to know that Apple Prime Customer Support service is 24*7 active to assist you whenever you experience any sorts of issues with this. Yup! No hassle, no waiting, your every single issue related to Apple will be resolved instantly at a single call to customer support. chat with Apple customer service.USA DAIL Itunes customer Care number our ensured specialists are available constant to offer most sensible courses of action immediately even by methods for our toll free number for Canada and USA.is advancing strong responses for the customers by methods for customer organization as it appreciates the burden and frustration a customer needs to encounter. It is advancing game plans by methods for different sources so the customer can pick the right one according to his tendencies. Itunes technical support. Our submitted gathering of is just a phone way and accessible immediately relentless. Itunes customers can come to us to benefit answers for any of their issues including the ones referenced here under Itunes best without toll number, there are 4 outright ways to deal with associate with them.The accompanying most perfect way to deal with banter with their customer reinforce gathering, according .Ipad Support Avail Ipad Support To Quickly Resolve All Ipad Errors Independent Ipad Support Phone number for Ipad Help The line of tablet computer designed, developed and marketed by Apple Inc.
    Oct 16, 2019 | Apple Computers & Internet
    Amazon Prime cusTOmER serVIce pHoNe #{+1-85O-8I2-4OO9 how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
    Oct 16, 2019 | Amazon Computers & Internet
    Computers & Internet Logo
    43 people viewed this question
    Ekse
    Alun Cox
