Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Hariston margarita a1324 advantage
I have an ariston margherita washer advantage and ill done what you said clear the pump but the light on the washing machine still flashing and the dial going click click is there something else wrong with it can you assist please.
  • 1 more comment
  • acuschieri Aug 16, 2008
    i checked the filter and the brushes on the motor as i have chanched them 3 months ago
  • damwalnuts Feb 02, 2009
    see above
  • Anonymous Mar 24, 2014
    I have a margarita a1324 advantage it is not spinning or draining. Dial going click and the light flashing on and off five times ....????????
  • 3 Answers
I had the same problem too and i found a solution on this website http://www.fixya.com/support/t219885-fault_ariston_washer_dryer I also added a few things when I was following the solution - my machine now works, i hope yours does too.
Posted on Aug 16, 2010
  • jonylim Aug 26, 2010
    I had the same problem. I start my wash cycle and it would fill with water then it would stop and the programme dial will start clicking around and won’t stop. I tried unplugging it for a day and it still wouldn’t work. My friend had the same problem and it cost his quite a bit to fix and I started to look for new washing machines. But before I bought a new one, I thought I’d try and see if anyone had the same issue and solved it. I only found one solution on the net and I gave it a try and it WORKED! Saved me a lot of money.
    Basically, it’s an electrical problem. You need to unplug the machine and open up the back of the machine, and unplug all the connectors that are connected to the circuit board. Plug the machine back in and turn the machine on for 2 min. then power off and unplug it and reconnect all the connectors back to the circuit board and it should work – well it did for me – detailed info in the link below.
    I found many people with the same problem so I thought I’d share my experience.
    Give it ago, I’m not sure if it would work for you but its worth a try. I found the solution here.
    http://cinnamonvision.blogspot.com/2010/...
    Scholar:
  • 97 Answers
Hiya
dont remember giving assitance before but i'll try and help you if i can. when the machine starts to click around count how many times the doorlock/on off light flashes as this indicates a fault code. it will usually go something like, flash pause flash pause etc until it flashes quickly then it restarts the fault sequence.
if you could let me know how many times then i'll be able to diagnose the fault quicker.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 19, 2008
Ariston Washer not running Programme
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
Mar 07, 2014 | Washing Machines
Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
Feb 28, 2010 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 (Advantage) Model A1435UK
Ariston Washer Dryer Margharita 2000. I have inherrited this machine but there is no user manual, does anyone know where i can get one from??
Mar 25, 2008 | Washing Machines
Ariston margherita 2000 advantage AWD10
Push the sun symbol button and set it on the time/or the function of the dryer. Thats it. I believe you were using the drying function without heating:)
Regards
Jan 24, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
612 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
