Question about Panasonic KX-FL511 Plain Paper Laser Fax
Failed paper pick up
Can't receive faxes or print copies. message says failed paper pickup.
tried cleaning the rollers with alcohol. restacked papers - no avail.
the fax has given great service for about a year. should i just dump it?
  • 1 more comment
  • Carlos Escoffery Aug 17, 2008
    cleaning roller with alcohol, re-inserting paper etc doesn't work. any other suggestion
  • Carlos Escoffery Sep 20, 2008
    Leroyal,
    you've broken my heart. Now since you're telling me to dump this fax, can you do me a huge favor?
    Please recommend to me a reasonably (not of them seem to be completely) reliable plain paper laser fax that I can buy as a replacement.
    Thanks
    Carlos
    My Panasonic KX-FL511 High Speed laser fax and copier worked perfectly for a year and has now died. It still sends faxes OK, but no longer receives or copies.
    I have restacked the paper, cleaned the roller and all of that but to no avail. It has been recommended that I dump it!
    If you agree with this, then fine. But please then tell me what a reasonable replacement machine of similar specs would be.
    Thanks
    Carlos
    Brigadier General:
  • 5,158 Answers
Have you recently bought paper for it... read your manual closely to see if it lists a maximum thickness of paper.
Robert
Posted on Sep 20, 2008
    Master:
  • 726 Answers
If the rollers are clean and no jams the printer has a fault and to tell the truth its to much to trouble shoot and fix ( me i would dump it there so cheap now days) i dont think there is nothing else to do with them incept clean the rollers and reset the machine take out the power for 5 mins thats about it
    Genius:
  • 2,120 Answers
Yes, dump it.
  • Leroy Elliott
    Leroy Elliott Sep 20, 2008
    Sorry Carlos,
    Since fax machines are being killed by the Multifunction Products (MFP), if you only need a fax, Panasonic is usually the most reliable. I've been servicing them for 30 years, and can only recommend Panafax.
    HP would be a second choice, only because you can order parts from their website.
    Best of luck.
    Leroy
I get plain paper or double when I received fax from my uf5300 laser fax.it print one page from 5 pages that sent and I got empty pages and double somtimes
Paper feed rollers and sheet feed pad dirty. Feed roller on top pad should be just below. Clean with alcohol. Papers have clay in them. Recycled is worst. It will glaze the pick up roller and pad.
Sep 21, 2014 | Panasonic PanaFax UF-8000 Laser Fax
How do I get my HP2575 printer to pick up the paper in the paper tray?
Hi jtheiss,
When you send a print or copy to the printer does the pickup tires attempt to pickup the paper?
Apr 12, 2012 | HP Photosmart 2575 All-In-One InkJet...
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
Our HP laserjet M2727nf does not feed the paper to print anything
just clean paper pick up roller whit wet cloth or alcohol...you can do this for ADF pick up rollers too if someday have the same problem whit ADF. Good Luck!
Oct 05, 2009 | HP Laserjet M2727nf Multifunction Printer
HP Deskjet 1200c will not feed paper. Fails to pick up paper from tray. If force pickup by hand can get it to start printing but moves paper in wrong direction as as positions for printing. Does not...
This sounds like a problem with the paper pick up rollers. I would suggest cleaning the rollers with a little isopropyl alcohol. Please make sure the machine is turned off when doing the cleaning. Let the rollers dry for a few minutes. If this does not work, The rollers would probably have to be replaced.
Aug 28, 2009 | HP DeskJet 1200c InkJet Printer
PagePro 1350W won't pick up paper
Clean the rubber roller that draws the paper in with isoproply alcohol, in future, blow dust off top sheet in paper stack before printing.
May 19, 2009 | Konica Minolta PagePro 1350W Laser Printer
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
The printer will not pick up a sheet of paper when I try to print. I get the message that there is no paper even though there is.
What printer do you have?
This problem is caused by "used" pickup rollers, that are the rubber rollers that pickup up the paper. As they cannot pick the paper, you get the message that there is not paper.
You may clean the rollers using a clean cloth with a litlle of alcohol and it should solve your problem.
Nov 28, 2008 | HP Office Equipment & Supplies
Kx-fl511 wont pick up paper
try cleaning the paper pick up rollers with rubbing alcohol, use a cloth rag and the alcohol, try to rotate the rollers so that you can clean all the way around
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
165 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
