Question about Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable i need to replace the on off switch on a mk2 technics 1200 any
I aquired a second hand turn table and the power switch was missing. Can I replace with a spare part? Where can I get these?
  • 515 Answers
The part is located HERE - but you will have to take apart your turntable from the bottom in order to replace it. It's not very hard, but if your not mechanically inclined, I would not suggest doing it, as you could cause more damage.
- OPTiC
The 1200s Expert
www.1200s.com
Posted on Sep 08, 2008
  • 33 Answers
Yah ofcourse  you replace a new one at www.turntablelab.com
Posted on Aug 14, 2008
Need to replace power cord - Technics 1200 MK2
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
Apr 28, 2013 | Technics SL-1200MK2 Turntable
Technic 1200mk2 pitch problems
Check for bad solderings on Q201 and surrounding areas.
Resolder IC101 and IC201. If that doesn't help, Q2 and Q3, both 2SD637R, could be broken. If that doesn't fix it replace the electrolytic capacitors. Cheers john. Styluscity
Mar 03, 2012 | Technics SL-1200MK2 Turntable
Technics 1200 mk2 just powered down and wont come back on
THERE ARE FUSES UNDER THE PLATTER AND BLACK COVER,REMOVE GLUE FROM AROUND REGULATOR DRIVER TRANSISTOR ON PCB.
Nov 12, 2010 | Technics SL-1200MK2 Turntable
Plastic top for technics 1200 mk2 turntable
Hi, What do you mean by this pls, you need a new top or how do you fix a broken one?
Thanks Mark H (superstar DJ)
May 03, 2010 | Panasonic Technics SL-1200MK2 Turntable
Technics sl 1200 MK2
Yes and the good news is the 2SD1265 will cost you under a few pounds including P&P from Grandata Limited.
www.grandata,co.uk
Apr 09, 2010 | Technics SL-1200MK2 Turntable
Technics 1200, no sound out right speaker
And it will be. I can almost steak my life on it. Easy to replace. Most djs had to already. Most off us went to Radio Shack and bought the 6 foot gold RCA's and cut them in half for both decks. Its not that hard to do. Any problems message me.
Oct 29, 2009 | Technics SL-1200MK2 Turntable
What is the best way of cleaning your whole tone arm and hight adjustment on a technics 1200 mk2 as just brought second hand one and works great but very dirty thanks dj fluant-c
Use common sense when cleaning. Don' t use water. Instead I find Windex works well. Just spray enough to loosen up any dirt/grime build up. DO NOT OVERSOAK. And just wipe clean. There really is no real trick to cleaning these things.
Get yourself some cotton swabs, a can of air, and paper towels, and your all set.
- OPTiC
The 1200s Expert
www.1200s.com
Aug 25, 2008 | Technics SL-1200MK2 Turntable
Technics 1200
Sounds like your transformer is blown. This is located underneath the turntable platter, right next to the main PCB (Printed Circuit Board). You'll have to have this replaced. I do not suggest replacing it yourself, unless you are handy with electronics. Otherwise, please take it to a service center for repair.
FYI, the part is located here (www.1200s.com), so you can purchase the part separately, then take it in.
We are the 1200s Experts!
DIGITAL ANALOG THERAPY
Jun 10, 2008 | Technics SL-1200MK2 Turntable
Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Oct 23, 2007 | Technics SL-1200MK2 Turntable
Technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Oct 19, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
483 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
