Question about Farenheit Car Audio & Video
In need a antenna for my in-dash tv tuner made by farenheit
Je ni pas le san don mon pc svp quoi je fiar
Posted on Aug 13, 2008
SOURCE:
How to install indoor digital tv antenna to a lcd tv & pickup digi channels
First, the LCD TV has to have a digital tuner in it. Older ones may not. If it does, then you attach the antenna connector to the TV connection that is marked TV IN or CABLE. Then, in the TV's menu, you would need to ensure that the digital tuner is selected. Once that is done, then, still in the menu, perform an "ON AIR" channel scan to find and lock in whatever digital channels that the antenna can detect.
Aug 05, 2015 | Electronics - Others
Do I need a digital converter box & antenna to get
It really depends upon your TV. If your TV is newer and has an ATSC tuner in it, then no - you'll just need the antenna. However, if your TV is older and doesn't have an ATSC tuner, you'll need an external tuner, what you're calling digital convertor, and an antenna to get the local channels. Use Google or another search engine to find the specifications for your TV to see if it has an ATSC tuner. Or, connect an antenna to your TV, run the channel scan (off-air antenna mode) to see if you get any local channels. If you don't, you'll need the external tuner.
I’m happy to assist further over the phone at https://www.6ya.com/expert/daren_80e8def41854e57e
Sep 29, 2014 | Audio Players & Recorders
Can I hook tr 2920 theather research speakers to a stereo
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
Emerson hdtv does not pick up any antenna signal
With digital OTA TV signals, a lot of things could cause you to fail to pick up a signal on any channel. First, do you have an indoor or outdoor antenna and how far are you from the transmitters for you local stations? Digital signals are either enough to for the tuner to interpret or you get no signal. Next check that the antenna is pointing at your stations' transmitters. Use antennaweb.org or tvfool.com to check the direction for your location. Antennaweb assumes an external antenna and provides a very conservative list of stations.
Check for buildings, hills or tall trees that might block the signal to your location.
If your antenna is providing a signal to several TVs, try a direct connection (taking out the splitter). You may need an amplified splitter to minimize the signal loss. Note: amplifiers (whether at the splitter or part of the antenna) can fail and become signal filters (blockers) instead. The direct connection tests this as well.
If another TV does pick up the signal from the antenna (at this point), then the tuner may have failed. It may also just be a weaker tuner compared to the other TV. Surges (for example, lightning strikes) can cause a tuner failure. In that case, you need a new tuner. (a stand-alone tuner like the converter boxes might work) or try a site like shopjimmy.com, searspartsdirect.com or partstore.com. SearsPartsDirect lists the tuner here: http://www.searspartsdirect.com/partsdirect/part-number/Emerson-Parts/Television-Parts/UTUNATSSP006/0057/528/Model-LC320EM9/0352/0333600?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50034435&diagramPageId=00001&productTypeId=x&searchModelNumber=LC320EM9&subCompDesc=Lcd%20tv&brandDesc=EMERSON&modelDesc=LCD-TELEVISION&blt=11&shdMod= .
This TV was made by Funai so you may see other TVs that use the same part.
I hope this helps.
(I have two TVs with different quality tuners. With one, when the antenna shifts slightly out of place, I can lose the ability to tune in the channels from the closest transmitters. The other TV does not lose the signal until the antenna rotates more than 90 degrees from its usual position.)
May 27, 2012 | Emerson LC320EM9 32 in. LCD HDTV
REEPLCE ANTENNA INPUT ON D52W19 RCA PROJECTION TV
Often they can be soldered back onto the tuner. But the tuner itself may need replacement which you can get tuners and the entire SSB which has the tuners already on them from www.tvrepairworld.com
Dec 18, 2011 | RCA D52W19 52" Rear Projection Television
Do i need a tv tuner to receive an internet tv signal?
No need,you must have only the antenna for internet,like smart broadband to watch online channel all you want to do is look only for the website that has an available online channel. It is also possible to installed a TV tuner to your computer but the antenna you will used is the antenna for TV(coaxial cable). The Antenna for internet and the TV tuner is separated, it is not the same antenna.
Hope this simple information could help you to solve your problem. Mam/Sir don't forget me to rate me up I really appreciate what grade will you given to me. Thanks a lot and God Bless.
Jul 14, 2011 | Computers & Internet
I have a 2 tuner tv. When Cablevision installed my digital cable box, I lost the 2 tuner capability. Is there a special way it needs to be hooked up to get back the 2 tuner capability?
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See tvfool.com for antenna types and direction or antennaweb.org for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
(please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
Nov 05, 2010 | Proview PA-32JK1A 32 in. LCD Television
No picture/signal
what u need to do is check your antenna as well as check that your tv is getting input on the av/hdmi/etc inputs, if your tv is still not picking up antenna signal, try on another tv unit or try the tv on anothe antenna signal. If you get no tv signal u need to replace the tuner printer circuit board, the one with the rf tuner module on it. Good luck.
Nov 15, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
52G786 ATSC Tuner no longer works
I have the same exact model tv...Love it...ATSC tuners is in definition an Analog tuner. As the broadcasting companies change over to Digital broadcasting before the deadline in Febuary 2009 more and more local or Non-Digital chanels are becoming obsolete. You would have to purchase a converter box for your tv if your not planning on getting cable. Another way to gois if you have an old cable line running through you house (no incomming cable) plug you tv into that jack. That also acts as a antenna. The sweet part of all this is that your tv do have a QAM tuner or Digital tuner built in just need that digital antenna to pair it up.
Dec 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Car Audio & Video Logo
32 people viewed this question
Top Farenheit Car Audio & Video Experts
xxxxxx xxx
Andrew Taylor
Andrew Taylor
NOEL
NOEL
Are you a Farenheit Car Audio and Video Expert? Answer questions, earn points and help others
