Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Connection Problem Hi I am having DLink Wireless Access point DWL-2000AP with given SSID name and password. Its working fine but it in middle at any time i gets stuck up and i loose the connection in my laptop. But i can see the LED status on wireless. In My laptop it shows " Limited Connection" or a red cross mark on the icon. Then i had to switch it off and again switch it on and i get the connection. Please help me. From Shrikant
  • Shri_007 Aug 14, 2008
    yes
  • crpm1222 Sep 11, 2008
    Hi I have the same problem. I have to reset my router when my other computers can't connect. My router is D-link WBR-1310
  • 298 Answers
Is your access point connected to a router?
Posted on Aug 13, 2008
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Aug 14, 2008
    What is the model of your router or access point? And who is the manufacturer?
SOURCE:
Power light is on, lan light is on, wlan light blinking. laptop says no connection. It asked me for ssi name i entered dlink
Is dlink the name of your network? I think your confusing it with the manufacturer.
Try This:
On the bottom of the router there is a number or ip address it should look something similar to this 192.168.0.1. Now, if you have access to the internet, if not, go use a friend's computer or the library and type that number EXACTLY as it appears in an internet browser (internet explorer, firefox, safari) where you would normally type a web address. You will be prompted with a password, enter the password. Now go through the setup and change the SSID when prompted to. Now enter that SSID which you just made when searching for networks on your wireless device.
This might solve your problem. If you have questions, contact me on my profile. Good luck!
Jan 03, 2010 | D-Link AirPlus Xtreme G DWL-2000AP...
How to make my DWL-2000AP works like a wireles card and is there any driver for it?
It sounds as if you want to use your access point to connect into a wireless network. A typical, simple wireless network includes (1) access points and (2) clients such as a wireless card in your laptop. Access points can only communicate with clients and clients only communicate with APs. However, many access points can be configured to be clients. Usually you would find that in the basic wireless setup page. I don't know if the DWL-2000AP can be set up that way, but you can check in the manual. If it can, then you would select that mode, then specify the SSID of the network you want to join.
Apr 15, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
How to install a password in a DWL-2100AP
The usual setup IP address for DLink wireless routers is
192.168.0.1
and the user login = admin and no password is required.
If you have not changed the password and the default SSID then it is recommended that you set a password and change the SSID so that it will help prevent someone hacking into your DLink wireles router and changing your setings to their advantage..
Feb 19, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
DLINK DWL-2000AP config
You should be entering the address of the gateway.
http://192.168.0.1
Oct 18, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
IMPOSIBLE INSTALAR
No es necesario controlador. Usted debe configurar el router mediante un navegador web (Internet Explorer).
http://support.dlink.com/products/view.asp?productid=DWL-2000AP
Aug 16, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Encryption failing
configure SSID in you wireless router,
it is used to secure your inetrnet connection & wireless device,
1. Go to IE page type the router ip &login to the router, confiuration u can See the SSID, there u mention the password to communicate the wireless to PC.
May 12, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
149 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
