Question about Electrical Supplies
Owners/repair manual I'm trying to find an owners/repair manual for a sears 2000 watt generator model # 580.328210 and am not having any luck, can you help?
  • Anonymous Jan 07, 2009
    I'm in the same boat. Sears sells an owners manual for $20. That's a bit high, but always an option.
4 Suggested Answers
SOURCE: lost manual 6250 watt coleman generator what oil to use and were
If it has the Tecumseh engine..
Above 40°F Straight SAE 30W
Below 40°F down to -20°F Straight SAE 10W or SAE 5W30 or
Below 40°F down to -40° SAE 0W30 Synthetic
Using multigrade oils above 32°F will increase your oil consumption. SAE 10W40 is not recommended.
Per the manual, all the oils should be marked A.P.I. Service SL/SJ, but you may have to use something to a newer standard. E.G.: Service SM.
The oil sump capacity is 1-5/8 U.S. Pints or 0.76 Liters.
Hope this helps.
Posted on Dec 31, 2008
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
  • 112 Answers
SOURCE: Is there anywhere I can download the pdf file -
http://pdfcatch.net/ebook/coleman+generator/
Posted on Jul 24, 2010
Service manual required
I can't find a free download on the internet, most are Owner's manuals or are not for the exact model you want - I don't know how similar similar models are. You might try the following:
http://cdn.powerequipment.honda.com/pe/pdf/manuals/00X31Z376011.pdf (from Honda, EU7000is owner's)
Honda EU7000i Model Info Super Quiet 7000 Watt Inverter Generator Honda...
This is the shop manual for the EU6500is model ($44)
Honda EU6500is Generator Shop Manual
owner's for the EU6500is
http://www.freeproductmanual.com/honda-eu6500is-manual
Finally a link to the search results most of the were taken from
https://uk.search.yahoo.com/search;_ylt=A9mSs2tVBShVngQA_xZLBQx.;_ylc=X1MDMjExNDcxNzAwMwRfcgMyBGZyA2FsdGF2aXN0YQRncHJpZANyOTBfV1hQeVNvT0twcW5oS3NxWlFBBG5fcnNsdAMwBG5fc3VnZwM0BG9yaWdpbgN1ay5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzMwBHF1ZXJ5A0hvbmRhIEVVNjUwMGlzQSBzZXJ2aWNlIG1hbnVhbAR0X3N0bXADMTQyODY4NjQ3NQ--?p=Honda+EU6500isA+service+manual&fr2=sb-top-uk.search&fr=altavista
You could try contacting Honda (relevant division) also; if they will provide the manual you want, it might be free
10.April.2015
Apr 10, 2015 | Honda EU6500isA - 5500 Watt Electric Start...
I am looking for an owner manual for my honda eu3000is inverter/gen. can you guys help me?
http://www.hondapowerequipment.com/products/manuals/Default.aspx
Here is the link to download for your particular model from Honda"s website. You may want to get your serial number to refine your search. Good luck and safety to you....
Mar 24, 2010 | Honda 3000 Watt Portable Generator
Generator fails to start microwave
I had to buy a 2000 watt inverter type to run mine
Apr 06, 2009 | Whirlpool GH7145XF Microwave Oven
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
