Question about Belkin Computers & Internet
Please insert the floppy disk labeled Wireless 11gUSB installation Disk
  • 477 Answers
Look here for the driver. download and unpack.
Posted on Aug 13, 2008
  • Filip Eastman Aug 13, 2008
    forgot the link sry.
    http://web.belkin.com/support/download/d...
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
Downloadable windowsxp boot disc winxp setup process
Windows XP Professional
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=55820EDB-5039-4955-BCB7-4FED408EA73F
or
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
Step 2: Run the Setup disk program to create the Setup disks
When you download the Setup disks, the download contains only one large program file. When you run the downloaded file, it extracts the files. You receive the following message:
This program creates the Setup boot disks for Windows XP. To create these disks, you need to provide 6 blank, formatted, high-density disks.
Please specify the floppy drive to copy the images to:
Type the drive letter for the floppy disk drive (this is typically drive A). After you type the floppy disk drive letter, you receive the following message:
Insert one of these disks into drive drive letter:. This disk will become the Windows XP Setup Boot Disk.
Press any key when you are ready.
When you press a key, the downloaded file starts to extract and copy the files. Continue to insert the blank disks as you are prompted to do this until all six disks are created. If the process is interrupted, you must run the downloaded program file again to create all six disks.
Make sure that you label each disk appropriately with the number that is specified by the program. You must use the disks in the correct order during the Setup process.
Step 3: Start your computer by using the first Setup disk to begin a new Windows XP installation
After you create all six disks, insert the first disk in the floppy disk drive, and then restart the computer. The computer must be configured to start from the floppy disk drive. You may have to modify the BIOS settings on your computer to do this.
The Setup process starts. Insert the other floppy disks when you are prompted. You must use the Windows XP CD-ROM to finish the Setup process.
hope it helps
May 20, 2012 | Iwill XP4 Barebone
Windows XP download
hope it helps
May 13, 2012 | Microsoft Windows XP Professional With...
Where is the floppy disc on my acer SA80 - Z970
I doubt you have one. Computer manufacturers have not been installing floppy disks for some years now.
Jul 07, 2011 | Computers & Internet
Installed new floppy. Set bios. Shows in explorer. After clicking on A drive, get mesage, "Please insert a disk into drive A:" Yes, there is good floppy in drive.
your magnetic head on your floppy disk is dirty.
you can clean it with floppy disk cleaner or open your floppy disk drive and cleaned it manually.
i suggest soft material like cotton and alcohol or other electrical cleaning liquid.
and hope help you.
Mar 04, 2011 | Mitsumi D353M3 (D353M3) Floppy Drive
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Windows XP , system goes to sleep immediately after booting.
CHANGE THE CD OS IF YOU HAVE ANY AVAILABLE SOME FILE NEEDED IF YOU KNOW HOW LOCATE THAT FILE DOES'NT MATTER BUT THE PROBLEM IS YOU DONT KNOW HOW LOCATE..
PROBLEM FROM THE CD INSTALLER
Jun 25, 2009 | Microsoft Windows XP Professional
Installation win xp in toshiba sattelite
ok my friend its not that easy but its always possible
fisrt just to know why u r unable to install xp because u have the HARD DISK SATA
and windows xp wont detect it because there are no definitions for SATA HDD.
so what should we do to fix this problem, you will know that by following these steps:
at the begining you need a floppy disk and floppy disk drive (i know thats not available in the new laptops, so u might need to buy one).
ok now we will need to download the SATA definitions from here:
http://www.4shared.com/file/37736514/7da1991f/raid138.html
and save it in the floppy disk (dont forget to unzip the file first).
now lets start the windows installation process (as usual).
u before you get to load the windows file there will be a prompt (in the buttom of the screen) asking you (press F6 if u need to install a third party...........) now press F6 quickly.
you will have a new screen with three options (S= specify, enter= continue or F3= exit).
now lets press S.
you will have a prompt asking you to (insert the labeled disk manufacturer ................).
lets insert the floppy disk now. and press enter
and when its asking you to select definition, select RAID driver.
and when its asking you about windows logo testing press yes.
and after finishing the definition process it will detect the HDD.
now continue installing windows as usual
enjoy XP (i know its a long story but its worth it :)
sure let me know what happened with u and for any other problems plz let me know
cheers
Aug 31, 2008 | Toshiba Satellite A135-S4527 Notebook
Epson smd349 floppy
Hi Elia, Could be a couple of things: -Your drive may only be a 720K drive. They will format 1.44 MB disks but only with a 720K format. The test is inserting a HD disk and try formatting it as HD. -The disk could be mislabeled, HD disks have two holes on end opposite the slide, one to write protect the disk and the other to signal to 720/1.44 capable drives this is a HD disk. -The HD disk could be formatted as a 720K disk even though it is an HD disk, reformat as HD. -The new, used drive could be damaged. -The drive could be configured as a 720K by the computers BIOS. You?ll have to enter the BIOS setup find the config for the A drive and set to 1.44MB. Let us know what happens and please don?t forget to rate the posting.
Jan 19, 2007 | Epson 1.44MB 3.5 Floppy Drive Floppy Drive
Computers & Internet Logo
20 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
