Question about Kenmore 63662 / 63664 / 63669 Microwave Oven
How do I install my Kenmore Microwave Oven 721.63664300 to the wall
I'm not sure if I'm missing an extra back bracket for my Kenmore Microwave Oven 721.63664300 . My brother-In-Law gave this microwave & I' m not sure if all the pieces for the installation are w/ it. I have the U shaped bracket for the back of the microwave. Is that all I need. It doesn't seem right to just mount that to the wall w/ just those 2 little lips on the bottom & that's it. If anyone has any ideas or install pics . Please let me know. My wifes been on my case to get this thing installed. Personally, I'd rather throw off a building. But you no the saying,"IF MOMMA AIN'T HAPPY >:( AIN'T NO BODY HAPPY >:(
  • Kenmore Master
  • 9,086 Answers
You can usually find exploded views and order parts & manuals by entering your model number here at the Sears parts site.
Posted on Aug 18, 2008
We have a Kenmore microwave oven Model # 721.80413500.
.The fan is not working. My husband took it apart and we cannot see how to replace the fan.
Jeannie
Posted on Aug 18, 2009
How to remove overhead kenmore 1000 watt microwave
Unplug the power cord and make sure it will come out easily when you start to take out the mounting screws.There are 2 or more screws in the cabinet floor above the microwave. Be ready to catch the microwave once the last screw is removed because it will drop in the front. Then lift the back of the case off the tabs on the wall mount bracket and the whole thing is in your hands.
Sep 23, 2014 | Kenmore 63792 Microwave Oven
MICROWAVE WON'T HEAT
HELLO.
If you are sure that your microwave is powered on but not heating.then you are having element fault with your microwave.this is the solution below,
Things you will need
  • Oven Heating Elements
  • Screwdriver Sets
    1 Turn off the power to the microwave at the breaker box.
2 Take out the screws holding the element bracket in place. These will be on the back wall of the microwave, or sometimes on the top.
3 Pull the element toward you a little bit until you see the wires behind it.
4 Unscrew the leads and take the bad element out.
5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
7 Fasten the brackets, making sure they're tight.
8 Restore power to the appliance.
Thanks.
Sep 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My ge spacemaker runs but does not heat items.
HELLO.
The problem of not-heating is from faulty element in the microwave.
  • Screwdriver Sets
Thanks.
Sep 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Need to know how to install
THERE IS EITHER OR BOTH A BRACKET THAT SHOULD BE SECURED TO THE WALL STUDS TO SUPPORT THE MICROWAVE AND THERE ARE THREE LONG SCREWS THAT GO THROUGH THE CABINET ABOVE THE MICROWAVE WITH AN OUTLET IN THE CABINET. THERE IS AN INSTALLATION GUIDELINE IN BOX. IF YOU STILL FEEL UNCOMFORTABLE HAVE YOUR SUPPLIER GET SOMEONE TO INSTALL.
Mar 10, 2010 | Kenmore 63252 Microwave Oven
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
I don't see how you remove it from the wall mount
do you have cabinets abofe the microwave. open and see if the brackets that hold it on are in there.
May 25, 2009 | Kenmore 63792 Microwave Oven
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for the spacemaker GE microwave oven model JVM164owj01
Here is the link to the installation manual. Cut and paste on the address bar of your browser. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF It is possible to do it by yourself, but its a royal pain in the a**, so have someone available to help you lift it into place and hold it while you get the screws into the cabinet above. You could use sheet rock anchors to put the mounting bracket on the back wall, but I would really suggest getting the mounting screw into wall studs instead, even if you have to drill a hole or two through the mounting bracket.
Apr 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 63662 / 63664 / 63669 Microwave Oven Logo
3,254 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
