Question about Xerox Office Equipment & Supplies
Fault code 010-333 xerox 7132 - Xerox Office Equipment & Supplies
  • islam_hmd Aug 16, 2008
    i have the soulotion, to resolve the problem these follow these steps:
    010-333
    start maintenance mode by pressing on 0 for five seconde and flowed by start. Code to access maintenance mode is 6789 and confirm.
    Go to system setting/common setting maintenance and diag/
    select NVM read write
    change the parameter to 744 044 in tow boxes
    and 0 as new value and validate.
    The must sort the problem.
    Thenk s.
  • Anonymous Mar 13, 2014
    How to solve fault code:047-310 problems on Xerox D95
    President:
  • 2,072 Answers
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
Posted on Aug 13, 2008
Recently I upgraded an Oracle 9.2 database to Oracle 10g using dbua the graphical utility provided by 10g for upgrade. But after upgrade whenever I start the database using Windows Service OracleServiceSID and then try to connect to oracle using sqlplus, I get ORA-01033 Oracle Initialization Shutdown in progress ( I get this error even if I try sqlplus half an hour after booting the system).=20
But if try to startup the database as follows, the database becomes operational and then I can connect to the database without above error.
SQL>connect /nolog;
sql> conn sys/password@(protected);
sql>shutdown;
sql>startup;
So where should I look into so that Oracle DB start with the Windows Service and I do not need to manually start the database.=20
Thx.
Posted on Jun 27, 2011
3 Suggested Answers
  • 53 Answers
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Posted on Jan 18, 2010
SOURCE: Need a windows 7 driver for a workcentre 7132
download the windows vista 64 bit driver. That worked for me
Posted on Aug 19, 2010
How to clear error 10-333 on xerox 7132 all in one
That error signifies a fuser problem where the thermistor does not detect the fuser coming to temperature. Need to replace fuser unit, part number 008R13022, see link.
http://www.iteminconline.com/008r13022_008r13022-xerox-workcentre-7132-fuser-110-volt.htm?source=froogle&gclid=Cj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzZg4C5Qd7jYhL14rJSJWIPdkZdVrtP4kPg2RlOQFweIaAnzV8P8HAQ
Apr 26, 2015 | Xerox Office Equipment & Supplies
How do i get get rid of 010-330 code on a xerox 7132
We encourage you to use our knowledgebase, MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year!
We can solve your problem!
Email patrick@mrc360.com for more info. Solutions for : Fault Code 010-330: The Fuser Motor is Not Rotating at the Specified SpeedMessage Related Fault Code: 010-330 Solutions ranked by relevance:
  1. Power the Machine Off and On
  2. Remove and Re-install the Fuser
  3. Replace the Fuser
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=468,E=0000000000016144604,K=4237,Sxi=2,Case=obj(3468)
Oct 07, 2014 | Xerox Work center 7132 copiers
Xerox 7132 printing dots after 35 pages
Check if it is with just one document or with all documents. Can also be coming from the job and not the printer
Apr 07, 2013 | Xerox WorkCentre 7132 Multifunction Color...
The Windows 7 mini drivers for the Xerox 7132 only provide a limited feature set. If I install the Windows 7 driver for the Xerox 7232, will it work with all features on the Xerox 7132?
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=WC7132&ripId=&Xtype=download
The above is the XP Vista drivers for the 7132.
The 7232 is a totally different machine and the windows 7 drivers for it will not work with your 7131 according to their table.
Also, according to Xerox's table, windows 7 drivers are definitely not available for the 7132. The latest drivers are for Vista, but that's not necessarily a bad thing, because windows 7 can run vista programs in its compatibility mode, or many times it works alright after downloading and installing the vista drivers.
Hope this helps!
Jul 14, 2010 | Xerox WC7232 Printer
I need the diferences between docucolor 12 and xerox 7132? please
Pretty vague question.
The Doc 12 probably has a Fiery Network controller, while the 7132 has a Fuji/Xerox controller.
The Doc 12 would have limited scanning capabilities while the 7132 can, depending on the config ordered, scan to E-mail, SMB, FTP, Scan to PC, and scan to a mailbox on the Xerox itself. If you have an embedded fax in the configuration, you can set it to catch incoming faxes and forward to e-mail, or a SMB or FTP folder on your PC or server.
The 7132 is rated at 8 pages a minute in color mode, and 30 pages a minute b&w.
The Doc 12 has been around since 2002, the 7132 is about 3 years old and has been replaced by the 7232.
Jun 23, 2009 | Xerox DocuColor 12 Color Copier
10,154 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
