Question about EliteGroup P4VMM2 Motherboard
ECS P4VMM2 PRoblem
Hello.. I really and badly needed your help... I have this ECSP4VMM2 Motherboard with P4 1.6ghz and 256mb of ram. It has a windows xp installed on it... I decided to reformat it because of virus infections... Whenever I try to reformat it to windows xp, it only reaches the part where it copies set up files(after r ormatting the selected partition), it hangs up and no progress is shown it's just about 38% of the copy process... I have tried it many times and i have tried using different cd, but still the problem is there. I decided to reformat the hard drive into another pc and it was successful and I didn't encounet any problems... When I put it back to it's original system unit(motherboard), a message prompts you to choose from safe mode , last known good configuration, start windows normally and etc... whenever i choose the normal one or the safe mode or the last known good config, it just hangs up after pressing the enter key. Then i tried to reformat it again using another cdrom, but still the problem is there... I am really mad with this problem... It's so annoying...
In my conclusion, the hard disk & the cdrom are ok... But where's the problem there? the BIOS? the motherboard? or the memory? or the CPU?
I really need to install a new windows xp OS and use my pc...
PLEASE HELP me with these... I would really appreciate it...
  • jay_edward19 Aug 13, 2008
    I've used 256mb ram with another computer before and it went well...
    I really need an answer why the computer keeps hanging up when I'm installing a new windows xp OS...
    And what should I do to successfully install a new windows xp...
  • asjadm May 11, 2010
    256Mb is very low for XP?
    need at least 1GB for good operation
  • 3 Answers
Try to replace your memory and use another power supply preferably 350 watts. thanks. good luck
Posted on Sep 19, 2008
    Scholar:
  • 45 Answers
Hey Nice to meet you. I've had this issue so many times in the past and it only has happened in rare occasions. It drove me off the wall, but in the end I figured it out. The only problem is that everyones issue is always a different problem. The smartest thing to do is to look at forums of ppl who have had the same issues.
http://www.hardwareanalysis.com/content/topic/13533/ <-is a link to a forum with many disgruntled and good ppl who had the same problem over this issue.
In many cases there are problems with the install disks or corrupted files. Some issues can be sectors on the Hard drive that are bad, it could be just a bad sector that hasnt been detected before untill you reformatted it. Its more than likely a virus or wear and tear that could have created that issue. Even the way it was installed or turned on and off can cause this.
For me I had a hard drive(80) that the first 10 GB i could partition and install xp. But if i were to partition the primary partition to be 20GB and 11GB, then the installation would not work. It would pause on the transfer. It really sucked. So my solution to this was to trace the bad sector and keep it out of the primary partition that im trying to install XP. The only real solution to fix that sector permantly is a high level format.
Another solution for many is the possibility that the CD/DVD does not work. or the CD/DVD drive does not work and many if you read the forum link above, has said they switched out the Drive at least 4-5 times then it worked.
Some ppl just had to try several times. Others traced it to their cables or improper connections.
I would suggest trying some of the things i just mentioned.
But my biggest suggestion is to look at this forum. They have some pretty good solutions that can be possible.
I hope this helps.
Please Rate, I would appreciate this.
Thanks.
By the way with my issues it only occurs on any NT version of windows(XP, NT, 2000, etc...) so far by experience. Because even with my HDD's I was able to install Linux, Windows Me, Windows 9x, and other OS's but also these OS's took very little space.
Posted on Sep 17, 2008
  • Anonymous Sep 17, 2008
    One more thing. user with the clarified request is right. I recommend that you at least have recommended requirements and 512 MB OF RAM OR MORE for your installation to proceed faster and possibly that can also be an issue is your memory space. Installations and transfer or files can take a lot of processing memory that will hang a computer in one spot for a long period of time or possibly freeze the computer where it hangs at. So it can be possible your installation does work. Just does not have enough to continue.
SOURCE:
My ram is 256 and how to upgrade to one gb ecs p4vmm2 intel r celeron
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=24&LanID=0
Your mainboard supports:
2 DDR DIMMs
Supports DDR266 / DDR200
Max. 2GB
You can easy add 2, 1gb modules.
I recommend 2 gb ram.
Good luck
Dec 02, 2012 | EliteGroup ECS P4VMM2 Supports Intel...
What is memory card EliteGroup P4VMM2 V8.1 Motherboard
You will need to install either DDR RAM (DDR 200 or DDR 226) or SDRAM (PC133 or PC100) memory. You cannot install both, you need to choose. The motherboard supports a maximum 2GB and there are two DDR and two PCI slots so 1GB +1GB would be the assumed maximum.
More details on your Motherboard here: http://www.motherboard.cz/mb/ecs/P4VMM2%20V1X.htm
Sep 03, 2010 | EliteGroup P4VMM2 V8.1 Motherboard
I'm running a NVIDIA GeFOrce FX5500 on ecs motherboard p4vmm2 with 1G of RAM. Screen hangs and when I try to run DOTA it displays a garbled screen.
i have a same problem with you vhanex. my system is (Asus motherboard KBu-X, AMD sempron 1.6GHZ, 1GB of RAM, Nvidia FX5500 256MB). when i play flight simulator, it`s work perfectly. but, when i play Dota or other games like NFSU, it display a grabled screen. Anyone can help us.. thanks regard.
Mar 01, 2010 | MSI FX5500-TD256 GeForce FX 5500, (256 MB)...
PC does not recognized all memory installed on an upgrade of RAM
The operating system perhaps does not support anymore ram then this.
Or the motherboard may need a firmware update.
You can get the latest firmware from the manufactures website
Oct 13, 2009 | EliteGroup P4VMM2 Motherboard
Ecs p4vmm2 v1.0 motherboard windows xp sp2 can`t get sound to work onboardsound
1st: try enabling the onboard audio devices from the bios setup menu. it should be somewhere in the on board menus.
2nd: try installing the latest drivers from ECS
i did not manage to find the motherboard model you specified. i did manage to come up with these:
p4vmm2[v1.1] drivers http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=46&DetailName=Driver&DetailDesc=P4VMM2%20%20(V1.1A)&CategoryID=1&MenuID=82&LanID=0
and also p4vmm[v1.0] drivers
please re-check the specific model you have and download the driver that suits you
Mar 02, 2009 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Ecs p4vmm2 v1 motherboard windows xp pro sp 2 can`t get sound
you din't install sound card...go google find vinyl deck..n download it....gd luck
ECS P4VMM2 driver
I lost my ECS P4VMM2 motherboard driver, and i need the driver to work my pc completely...
Aug 11, 2008 | ECS RS400-A (V1.0) Motherboard
Upgrading my processor
The following link will give you the information about what processors will fit in the 478 socket for the motherboard you gave in your post. It also gives you information on how to determine if a processor is compatible with your motherboard and information about upgrading. If this is not what you are looking for please let me know so I can assist you further.
If you would not mind rating my help, I would appreciate it. Please rate my help only when I have fully helped you. Thanks
Jul 15, 2008 | EliteGroup ECS P4VMM2 Supports Intel...
Critical after DDR333 upgrade
cadyshack,
I got your latest version (8.1) motherboard on my screen & ECS shows your board does not support PC2700, only PC2100.
Downloaded your manual to verify this.
Notice you started having problems after upgrading RAM.
Link to your manual:
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=436&DetailName=Manual&MenuID=7&LanID=9
This motherboard accommodates two 184-pin DDR DIMM
sockets for up to 1GB memory. Supports PC2100/PC1600
unbuffered non-ECC DDR DIMMs.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=548&Nav=|c:147|&Sort=0&Recs=10
Good Luck!
Mar 18, 2008 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
76 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
