You gave model number 590.752310.But i think exact model number is 580.752310.---------
To replace the pump manifold.It is held in place by 2 o-rings. The check valve should pull out of the manifold by hand.These pressure relief valves usually are just a ball and spring type valve the will corrode the ball and/or the pump housing or the seating surface causing pitting, there for rendering it inoperable. On a very few of these pumps, there are a couple of "PLASTIC" valves that will break... causing the pump to fail.-------The valve would be under a hex nut on the pump head and if debris is in them pressure will fail. They are a spring seated assembly. they come out after the cap is off with a pair of needle nose pliers.------
Click this link directly for complete break down of your pressure washer.
http://www.ppe-pressure-washer-parts.com/sears-craftsman-pressure-washer-580752310-parts
The exact part number of pump assembly is 193568gs.
For manual of your pressure washer.Please click the link below
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0409655.pdf
This should help.Thanks.Helpmech.
