Question about Philips Televison & Video
Picture on screen is to big for screen - Philips Televison & Video
    Scholar:
  • 167 Answers
HELLO. IT SOUND'S LIKE SOME ONE HAVE TURNED UP THE V HIGHT ON YOUR SET. THERE SHOUND BE A CONTROL POD .!!! ON THE BACK OF YOR SET .!!! FOR THIS OR.!!! IT'S ON THE IN SIDE OF YOUR SET.!!! ON THE MAIN CHASSIE. .!!! YOU SOULD LOOK FOR IT.!!! AND TURN IT DOWN.!!! BUY TURNING IT CONNTER CLOCK WISE.!!! WITH A SMALL SCEWDRIVER.!!! TURN IT ABOUT 1/16MM. VERRY LITTLE.!!! LOOKING FOR THE VERTICAL SECTION ON THE CHASSIE YOU SHOULD SEE A SMALL POD .!!! WITH A V-HIGHT.!!! OR ONE WITH.!!! A (V-LENTERY).!!! THE HIGHT POD IS FOR THE CENTER OF YOUR SET UP..!!! & THE V-LENTERY .IS FOR THE CENTER OF YOUR SET GOING DOWN.!!! ONE IS FOR UP.!!! AND THE OTHER IS FOR THE PITCURE TO GO DOWN.!!! TURN THE UP CONNTER CLOCK WISE.!!! 1/16 MM. FISRT.!!! THAT SHOULD BRING YOUR PITCURE DOWN.!!! REMBER TO FIRST .!!! TO UNPLUG YOUR SET.!!! BEFORE TRY THIS.!!! AFTER UN[PLUGING IT DO THE AJUSTMENT.!!! THEN PLUG IT IN AND SEE WHAT HAPPEN.!!! REPET.!! TILL YOU HAVE IT TO THE HIGHT YOU WANT.!!! HOPE THIS HELP'S YOU .!!! LET ME KNOW.!!! OK " GOOD LUCK"
Posted on Aug 13, 2008
SOURCE:
Can't see all the words on guide screen picture too big
Try grabbing your remote press the menu button go to picture and see if its on zoom insted of normal or stretch
Feb 20, 2012 | Vizio L32 32 in. LCD HDTV
Picture Is Too Big for Screen
Sounds like your cable box is zoomed in, I run into this a lot when running service calls. On most cable provider's remotes there is an 'aspect' button next to or around the '0'. Try that and see if it helps you out at all :)
Feb 24, 2010 | Samsung LN55B650 55 in. LCD HDTV
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
Picture aspect ratio? Picture is too big for
Try VIEW MODE button on the remote or ZOOM button on the remote from cable box.
Oct 25, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Picture goes big and small
Look for button on remote labeled size,aspect ,format or zoom. You can change the picture size to your liking. Different channels are broadcast in diffrent formats.
Apr 26, 2009 | Televison & Video
Picture too big for screen
you need to go into the picture menu, and play around with the screen size options.
Jul 12, 2008 | Televison & Video
GO TO MENU VIDEO SETTINGS AND RESET TO FULL FORMAT SETTING , GO TO JVC.COM AND DOWNLOAD THE OWNERS MANUAL GUIDE ,
May 16, 2008 | Televison & Video
No picture on flat screen new, with cable
IF THIS IS A LCD---TURN ON, AS NORMAL AND HAVE A SIGNAL INPUT,,CABLE ,SATELLITE CONNECTED TO THE ANTENNA INPUT .MAKE SURE YOU HEAR SOUND.. HOLD A LIGHT (THE BRIGHTER THE BETTER) IN FRONT OF THE THE SCREEN ('BOUT 3 INCHES)--IF YOU SEE A DIM PICTURE---BAD SCREEN AND THATS BIG BUCKS---IF STILL NO PICTURE--CIRCUIT BOARDS AND USUALLY THATS BIG BUCKS!! GOOD LUCK
Mar 16, 2008 | Sanyo DS27930 27" TV
4 Scrolling black boxes with the picture showing in the background
PIP DISPLAYED IN ALL FOUR CORNERS OF PIX. UNPLUG UNIT MOMENTARILY TO RESET. or the pip modual has failed.
Mar 16, 2008 | Televison & Video
Televison & Video Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
